Old 11-06-2010, 08:06 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
Originally Posted by Jerry H. View Post
I'm with Steve, I'm not a fan of two tones, if it were me I would go with a solid color. Red would be a killer. I would go with the 455, as you can make it look 95% like the 389 and most folks can't tell. More power and easier to find parts. Please post pics as you proceed!
Here is a pic of your wheel/tire combo:
Beautiful 65!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!!
Old 11-06-2010, 08:09 PM
That is gonna be one cool 62... Yeah, id probably go with the 455... use old style pistons and heads/intake/timing cover/balancer. it'll look stock and you will have an easier time with trans and starter stuff. Ive heard that Ross makes pistons with valve reliefs for newer and pre '65 engines on the same piston. That would be the way to go in case you decided to switch heads...
Old 11-26-2011, 10:55 PM
62cat's Avatar
62cat 62cat is offline
Default more progress
got the cat back in the shop and made some progress havent touched it in a year.installed the new engine 455 w/edelbrock round ports my brother in law built this engine with the help of one of his patients louie b of LRB performance machine company. it was supposed to go in my sons car but uncle bob got a little carried away and built a bit to much engine.trans is a transmission specialties th350 w/reverse manual valve body. aeromotive fuel system.
ID:	264931   Click image for larger version
ID:	264932   Click image for larger version
ID:	264933   Click image for larger version
Old 11-26-2011, 11:04 PM
62cat's Avatar
Default cutting
oil pan didnt clear so we had to modify cross member a little. spun trans crossmember and welded on a mount.ran all the fuel lines new brake lines. need a manual sterring box to install maddog headers. fuel cell pump and battery all going in trunk.
ID:	264937   Click image for larger version
ID:	264938   Click image for larger version
ID:	264939   Click image for larger version
Old 11-26-2011, 11:09 PM
62cat's Avatar
Default hood massage
pontiac service sign perfect template for hole for carb and mounting sd scoop.
ID:	264941   Click image for larger version
ID:	264942   Click image for larger version
ID:	264943   Click image for larger version
Old 11-27-2011, 08:30 AM
61-63's Avatar
61-63 61-63 is offline
Very nice car.
'62/'63 post cars take two tones well in my opinion. I've never seen cream over red so it ought to be a unique car.
Old 11-27-2011, 09:55 PM
kustomlarry kustomlarry is offline
Car looks awesome Ray. I am glad you are moving on it. Now I just need to push ahead on mine.
Old 12-12-2014, 12:16 AM
62cat's Avatar
Default my 62
I need a push im stalled. Any encouragement appreciated.
Old 12-12-2014, 08:49 AM
61-63's Avatar
That will be a nice car you need to get it finished. Have you considered putting a dual quad setup on it?
Old 12-12-2014, 10:35 AM
62cat's Avatar
Default stalled
I was kicking ass on this project. Should have been done a few years ago. Now from sitting im going to have to blow it apart and redo a few things. 2 fours are in the plans. Want to get it moving first then sneak up on it and try different stuff.
Old 12-12-2014, 11:09 AM
Doug Doug is offline
Cool Damned cold garages!
Encouragement when winter is here? Tools feel like holding icicles? Yuck!
Consider how much you have done since the start. Heckuva lot accomplished. Obviously, you know what you are doing.
Apparently, you have had a lapse of progress covering a few years. This happens many, many times when guys tackle a big project. We get distractions (one being we have too many irons in the fire).
I think that there is something "psychological" about these "lapses" in that when you get into a project and you do the big, challenging things, you have a let-down for enthusiasm to finish it up with the small, routine stuff.
You had a vision when it began. Buying the car, scrounging for parts, jumping into the work, all of this is part of your own particular pleasure and enjoyment. However, there are many people on the sidelines cheering you on, whether you know it or not. They want to see that thing on the road! Having a '62 Catalina project car myself, I certainly do!
Old 12-12-2014, 12:42 PM
straycat's Avatar
straycat straycat is offline
Hi Ray, I think Doug said it best above, you have had some distractions. But eventually you will be out there with us again. Paul is running again with the new motor and that crazy tri power set up. Are you going to use Seniors SK dual quad? It's cool.
Old 12-12-2014, 12:53 PM
hellerods's Avatar
hellerods hellerods is offline
Default Don't let a slow down in your project...............
Don't let your project get the best of you today, just hang in there and work on it as time and $$ allow you to. I have been on my 64" Cat for about five or so years and have had health and $$ and you name it issues but just kept going no matter how slow things get. There is always some small thing you can do, maybe a beer , the radio, sitting on a five gallon bucket in the car in the garage is all I did some days. I still need some new upholstery, carpet, and a better tune up, but it's almost done and you need to hang in there , your car is very cool and you will be very satisfied when you get it done. Lee
Old 12-12-2014, 03:09 PM
62cat's Avatar
Default progress
Im going to take some updated shots and post them.I guess i have been busy past few years. got a little side tracked. And we just bought a new house. Didnt move far around the block. Just room for the mother-in-law.
Old 12-12-2014, 06:05 PM
63gpman's Avatar
63gpman 63gpman is offline
How about a race? As in the first person to get their car done wins?? I need some motivation also, but looks like you are farther along than I am. I know that MPKind also is in need of some motivation (like all of us) to get his 65 done.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 12-13-2014, 11:29 AM
Engine-Ear's Avatar
Yes, share pics, 62cat!
63gpman, great idea! FWIW, I have a similar race going with a friend of mine here - we both own 62 GPs. We decided that we would be premiering them both -as finished cars- at the 2017 POCI convention.
Old 12-13-2014, 01:54 PM
ho421's Avatar
ho421 ho421 is offline
Game on. Im hoping to take my 63 and the original owners to louisville this year. any motivation helps.
  #38
Old 12-13-2014, 03:43 PM
real61ss's Avatar
real61ss real61ss is offline
Damn Ray, I wish you hadn't cut that hood up, I've got the hood off your old Cat here in my shop that you could have had, I sold the scoop but the hood is still taking up space here.
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
  #39
Old 12-13-2014, 03:47 PM
63gpman's Avatar
Starting a new thread called the Race is on!!
Brad Hansen
  #40
Old 10-25-2016, 12:20 PM
62cat's Avatar
Default 62 progress
Almost ready for it to move under its own power. Last year around this time we decided to just paint it and put it back together with what parts we had for it then go from their. I just got new Mark Williams axles and Strange rear discs for the rear to go along with the 4:56 spool i had done 4 years ago. Driveshaft needs to be made along with a custom rollcage going in. Some wiring and interior after that and i should be ready for the street. Heres some more up to date shots.
ID:	439370   Click image for larger version
ID:	439371   Click image for larger version
ID:	439372   Click image for larger version
ID:	439373   Click image for larger version
