Old 02-21-2020, 07:02 PM
webfoot's Avatar
webfoot webfoot is offline
Default Rear suspension upgrades
I posted in another thread of mine about a few suspension upgrades, one was custom lower rear control arms, they use poly bushings and are available in nearly any size.
https://thorbros.com/4-link-parts/4-...-poly-bushings
I finally finished my upper rear control arms, they are adjustable as well in case you need to set your pinion angle.
I used some major overkill rock buggy joints which were $70 a piece, but that is not necessary. More economical ones are available for about half the price.
Threads on these are 7/8, I had tubing inserts (one hex, one regular) welded in by a friend of mine into a piece of DOM. Pair of jamb nuts and done!
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 02-23-2020, 11:06 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Very nice, definitely look strong enough. I just made a pair of upper adjustable arms from Afco 3/4" RH\LH threaded steel tubes and Comp Engineering chromoly rod ends. Summit part numbers AFC-19509 (9" long, but 8" would have been enough), rod ends were CEE-6154 and CEE-6155. Those particular rods ends are for 5/8" bolts at frame and rear axle housing...upgraded those from 1/2" for hard launches with a 4.10 gear.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 02-24-2020, 11:13 AM
mr67gp mr67gp is offline
Nice. johnny joints will hold up, just be sure to grease them.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
