Old 01-20-2020, 10:21 PM
WARCHIEF400 WARCHIEF400 is offline
Default 1970 GTO Parts
1970 Ram Air 4 bolt main shortblock std. bore needs to go 30 over $4000.00
1970 Quadrajet Carb pulled off running car #7040263 $400.00
1970 AM &FM RADIO PULLED OUT IN 1983 WORKS $475.00
1970 AM RADIO WORKS $200.00
NOS 1970 Wheel well moldings $850.00
1970 pair of used rear wheel molding $200.00
1970 GTO grills $300.00 for pair $150.00 singles
1970 GTO Front Headlight housing assemblies $250.00
1970 power brake booster $50.00
1970 lower main duct and vents $125.00
1970 Intermediate steering shafts $50.00
1970 Rear Windshields $80.00
1970 Coils $25.00
1970 Oil Filter housings $85.00 each
1970 front lower window reveal molding $60.00
1970 rear front upper fender chrome moldings $30.00 pr.
1970 Throttle cable $45.00
1970 Turbo 400 Transmission oil pans $50.00
1970 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1970 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1970 door vents pr. $20.00
1970 positive battery to starter heat shield tube,
1970 window regulators set of 4 $150.00
1970 brake pedal assembly $100.00
1970 emergency brake pedal and bracket $75.00
1970 rear license plate bracket and holder
1970 water thermostat housings $20.00
1970 door hinges $50.00
1968-72 points distributors $80.00
1970 wiper transmission assembly (2) $75.00
1970 blower motors $25.00
1970 a/c inner boxes $150.00,
1970 headliner bows $50.00 set
1970 Harmonic balancer $50.00
11 Bolt Timing Cover $110.00
11 Bolt Timing Cover withy divider plate and pump $150.00
1970 Full length windage trays $85.00
1970 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00
NOS A/C Delco PVC $9.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
NOS Three prong Thermo Switch for rally gauges $250.00,
1971 GTO Rear Taillight lenses $150.00 Each
1970 Rear Taillight housings $75.00 Each
1969-72 Goldenrod/Tan wheel crack free $125.00
1969-72 auto shifters $135.00
Fuel escentrics $35.00
1970 harmonic balancer $50.00,
flexplates $35.00
1970 inside glove box liner $45.00
1970 Standard Gauge & Speedometer cluster $65.00
1970 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00
assorted stainless moldings,
1970 driver side lower black dash metal trim $50.00
1970 radio rear support bracket $25.00
1970 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
1970 door glass $100.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
1970 pillar post covers $45.00
new points and condensers __________________
Timmy Mallory Email me at temallory@msn.com
Timmy Mallory
Old 06-10-2020, 05:50 AM
ramairformula74 ramairformula74 is offline
Do you have photos of the A pillar post covers? Thanks Mike
1972 GTO, Lucerne Blue, M22 Rockcrusher. 1974 Ram Air Formula 400,4spd,3.42 posi,honeycombs,much more.Rare Bird(sold). 2005 GTO Midnight Blue 6spd( sold).
Old 06-24-2020, 05:36 PM
text meat 3018921550
Timmy Mallory
Old 06-24-2020, 05:43 PM
JAL71TA JAL71TA is offline
Is this still for sale?
Jim
Old 06-27-2020, 05:42 PM
yes its still available text me at 3018921550
Timmy Mallory
Old 07-01-2020, 08:05 PM
A Rare 70 A Rare 70 is offline
Any chance that you would happen to have a correct part number 5 blade flex fan and spacer for 70 GTO?
Thanks,
Randy
Old 07-01-2020, 09:15 PM
Randy I might have a spacer but I do not have anymore fans.
Timmy Mallory
Old 07-02-2020, 08:07 AM
Brewster's Avatar
Brewster Brewster is offline
Randy, sent you a PM
