69gto conv.
Hi guys,I have a question.Does the rear qtr. and the deck filler panel get molded together?ORRRRR is there a distinct line between them?Thank you for any help,I hope I explained it right.
Tim |
The Following User Says Thank You to Tim66 For This Useful Post: | ||
The factory leaded the seams. They also were known for cracking due to body flex at the seams.
Not sure why they didn't have a seam like the hardtops and coups. I plan to do as some have. Remove the lead and weld a small patch in and skim with filler so as to not crack new paint.
I would remove the lead. weld the seam. Then patch over the seam. Just did this a few months ago on my 68.
What's the best way to remove the lead?
I used a torch and a brass wire brush to get solder out my roof joints.
Greg Reid Palmetto, Georgia |
You're going to find a seam similar to the one I'm posting of a '68 that we are doing. You will need to weld the overlapping edge solid before any filler goes over it, or you're going to see cracks appearing later. |
Thanks. Does the torch warp the metal? Do you try to keep the surrounding metal/paint cool with a rag to keep from damaging the paint further?
Two things in your favor. The layered metal is slow to soak up heat, plus lead has a low melting point and will turn to liquid with little effort. Use a brazing tip with a soft blue flame and it will puddle quickly. That said, you aren't likely to warp anything.
Will a hand held propane style torch do the job? That's all I have.
That's what I used. Lead melts pretty low compared to the surrounding metal.
Sent from my moto g(6) play using Tapatalk
Thanks. That's great to know.
