Old 11-19-2019, 10:30 PM
footjoy's Avatar
footjoy footjoy is offline
Default Where to get Tri Power Valley pan
I realize that the valley pans are not tri power specific but I am looking for a rear pcv valley pan. Do they reproduce this I know there is concern with sludge in the used ones.
Any help would be appreciated.
Greg
Old 11-20-2019, 04:46 AM
Kenth's Avatar
Kenth Kenth is offline
https://butlerperformance.com/i-3121...pe-n178wd.html
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-20-2019, 09:10 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
If your original valley pan is not rusted. You can separate the two halves, clean, then weld back up. We've had good success doing that.
Old 11-20-2019, 09:16 AM
242177P's Avatar
242177P 242177P is offline
Originally Posted by Kenth View Post
That part number, ape-n178wd, suggests that it's an Ames piece.
Sure enough, N178WD is in their catalog and the price is the same.
Just figured I should mention that our host also has it.
Old 11-20-2019, 11:32 AM
footjoy's Avatar
OK thank you very much for the info.
Greg
Old 11-20-2019, 12:21 PM
Scott Thelander's Avatar
I have a very clean, cleaned, original if your looking for an original...
scott68gto@comcast.net
Old 01-08-2020, 09:18 PM
footjoy's Avatar
Got one thanks
