Old 09-05-2019, 01:32 PM
NAPA68 NAPA68 is offline
Default 76 Trans Am P/S pressure hose source
I am in need of a new P/S pressure hose for my car. When I recently replaced one on a 78 (which the same part number is cataloged) the hose was quite a bit longer and I was not real happy with the fit.
Any suggestions as to where to source one? Anybody have an NOS hose for a nice price?
In advance, thanks for your consideration.
Tim
Old 09-06-2019, 09:23 AM
Aus78Formula Aus78Formula is offline
What brand did you use? Many only quote GM numbers as a replacement that works, not one that is exact. That way it often suits several models. Or else make one to suit.
Old 09-06-2019, 03:51 PM
76TA462 76TA462 is offline
I few years ago, for my 76 TA, I purchased my ps braided lines from March (P327 - Saginaw Power-Steering Hose Kit for GM Steering Box with Flare Fittings (1978 & Older) when I bought their ps pump (P304) etc. They worked perfectly for me, but I'm not sure it their OEM styled chrome pump has the same connections as the original pump. All good at the steering box ends.
Old 09-06-2019, 10:09 PM
I used a NAPA hose on the 78. It looks to be the same length as the Ames unit (and others)
Old 09-07-2019, 10:52 AM
77 Canamman's Avatar
The GM part number from a 1977 parts book is 7816969, and is listed as fitting 1971-76.
Partsvoice lists this dealer as having one:
Craig Motors -Napa Gm NAPA, CA 94559
The Parts Place makes a repro of that part. However, buyer beware.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 09-18-2019, 01:04 PM
I purchased the hose from Parts Place. Not a bad piece. Correct in length as well as ends. Hose is from Eaton and therefore is not a good piece for a car that will get judged. I appreciate the input from those who responded.
Tim
