Old 11-06-2019, 05:29 PM
Scottch Scottch is offline
Default Steering Box Part Needed
I was almost done rebuilding my fast ratio steering box for my 1969 Firebird when I discovered a broken part on the input side of things. Does anyone know how or where I can find one of these? I think it used to be one part not two and definitely not three!
Name:	Box input part 1.jpg
ID:	523804   Click image for larger version
Name:	Box input part 2.jpg
Old 11-06-2019, 07:10 PM
Scott Thelander's Avatar
I think he goes by carhex on here he rebuilds them
Old 11-06-2019, 09:01 PM
Tim john Tim john is offline
Reach out to "Turn One" in Saginaw, Michigan. They built my 69 box to 2-1/4 turns lock to lock. They are right down the road from Saginaw Steering Gear where your box was originally made, the owner of Turn One actually worked at Steering Gear, (now called Nexteer) he currently runs his own shop (Turn One). He builds ALOT of boxes for Nascar. I am real pleased with mine.
Tim john---
Old 11-07-2019, 08:28 AM
AG's Avatar
AG AG is offline
Tim john---
How much for the rebuild?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-07-2019, 09:49 AM
389 389 is offline
Call Lee and get one of there new 800 series boxes. I have the 14:1 with a 30 pound valve and it does everything well. Steering wheel snaps right back to center after a turn like a manual box, even with just a degree of caster! I never had a power steering box do this before and I've had many boxes..
Old 11-07-2019, 02:24 PM
Did you have to get a new power steering pump to work with the Lee 800 box?
Old 11-08-2019, 02:17 AM
Thanks for the help. Turn One was very helpful, but they said they would need to rebuild the whole unit themselves at a cost of $300. I am still on the lookout for the part, but may have to go the rebuild route.
