Old 01-05-2020, 08:21 AM
64gp4spd 64gp4spd is offline
Default 3.42 gears, and 3.08 gears and posi
I have a set of 3.42 gears on a open carrier
They are out of a 73 Pontiac Safari
Great Shape $250.00 + Shipping
Also. 3.08 posi out of 71 Grandville
$300.00 complete + Shipping
Old 01-12-2020, 09:05 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
What rearend did it come out of 10 or 12 bolt? Chevy or Pontiac? Thanks.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 01-12-2020, 09:37 PM
Neither, '73 Pontiac Safari has a '71-76 8 7/8 MP series 12bolt.
Very hard to find gearset. the midratio 31spline MP series carriers are seldom avail too.
Old 01-12-2020, 09:40 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Both of these sound like 8-7/8" 10-bolt cover parts.
Old 01-12-2020, 10:06 PM
The rear is a 12 bolt, 12 bolts attach the ring gear to the carrier.
The 71-76 MP series 12 bolt is a direct descendant of the '65-70 P series 12 bolt used in '65-70 Pontiac B series. Some later GM literature will reference the later rear as an 8.75.
The MP series ring & pinion changed for '77 big cars. The pinion on the '77-83 model MP series gear set is longer, & as such the last MP series gear sets will not work in '71-76 or earlier housings
Old 01-12-2020, 10:45 PM
Correct 10 bolt cover, 12 Bolt Ring Gear. These are the same as 65-70 Full Size Pontiac except the Pinion Gear on the 71-76 is 30 Spline
where the 65-70 is 28. Interchangeable with 65-70 with 30 Spline Pinion Driveshaft Yoke
Old 02-09-2020, 04:10 PM
Default 3.42 Ring and Pinion Photos
$200.00 plus shipping
ID:	531503   Click image for larger version
ID:	531504   Click image for larger version
Old 02-09-2020, 04:15 PM
Default 3.08 Posi Photos
$250.00 plus shipping
ID:	531506   Click image for larger version
ID:	531507   Click image for larger version
ID:	531508   Click image for larger version
Old 02-18-2020, 08:15 PM
SOLD
