Old 01-14-2020, 03:01 PM
Firedup6975's Avatar
Question Sending unit
Is there a way to test the fuel sending unit out of the tank?
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
Old 01-14-2020, 03:21 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Yes, using an ohm meter, you can measure the difference in ohms by moving the float arm from full to empty positions. If you can't get a reading the fine wire that is wrapped that board has a break in it, and the sender is junk.
I'm assuming your gas gauge isn't working...Mine is not either. I had the sender out of the tank some time ago, and it functions fine...I'm thinking my gauge may have a problem. It's either that or a wiring problem...somewhere between the tank and gauge, which will be a joy to figure out...
Shut it off
Shut it off
Old 01-14-2020, 03:37 PM
Bought this car two years ago it was never road worthy asthe brakes were toast!! Literally and we’re finally set up in our shop with a lift to start working on it. Guy who had it did something with the gauges we have the tank out, so rather then having to pull it out again after everything is detailed, wondered if we might be able to test it. We know we need the O ring and the mesh bag, but the unit looks good. Where would one get that meter?
ID:	528829   Click image for larger version
ID:	528830   Click image for larger version
1977 RED TA
Old 01-14-2020, 03:41 PM
Also can you tell me why the unit for an air conditioned car is different from a sending unit for a non air conditioned car? Mine has air, and I cannot seem to find a unit anywhere for an air condition car should we need one if this one we have needs replaced.
1977 RED TA
Old 01-14-2020, 05:37 PM
77 Canamman's Avatar
Lightbulb
https://www.ebay.com/itm/76-81-Fireb...kAAOSwgmJX1wYk
Also, check your local Autozone. They carry Spectra parts, and last I knew, they could order the proper sending unit.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-14-2020, 05:41 PM
Tank you!
1977 RED TA
Old 01-14-2020, 06:00 PM
Best way to troubleshoot a GM fuel gauge: unhook the wire from the sending unit. At this point, the gauge shoot past full. If you ground out the wire from the sending unit, the gauge should read empty. The sending unit is a 0-90 ohm impedance. At empty, there should be close to 0 ohms resistance as read by an ohmmeter. At full, it should read close to 90 ohms.
Old 01-14-2020, 06:01 PM
Tank you!
Pardon the pun? lol
Old 01-14-2020, 06:05 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I pulled a NIB GM I had bought years ago, resistor not working now!
Skip Fix
Old 01-14-2020, 06:50 PM
Originally Posted by 77 Canamman View Post
Pardon the pun? lol
Oops spelling error
1977 RED TA
Old 01-14-2020, 06:51 PM
NIB?
1977 RED TA
Old 01-14-2020, 08:10 PM
New In Box
Old 01-14-2020, 08:31 PM
New In Box
Thank you! I’ve never heard that one. Lol.
1977 RED TA
Old 01-14-2020, 08:36 PM
That e bay one is definitely the one we need, funny I did search e bay and did not see this. I guess it’s the way you word the search. that one doesn’t say if the O ring is included. Hmmmmmm guess I’ll message the seller Tamraz. If not I know NPD has it for $2.50
1977 RED TA
Old 01-14-2020, 10:48 PM
Take a new pencil with a soft eraser on it. Gently rub the eraser across the resistor wires. Take a piece of very fine wet/dry sand paper (600-1000 grit), gently rub the contact side of the moveable arm. Should work....
Shut it off
Shut it off
Old 01-14-2020, 10:49 PM
New In Box
Nail in backtire
Shut it off
Shut it off
Old 01-14-2020, 10:53 PM
You can take a fuel pump strainer for one of the older cars with an in tank pump, cut one end off and clamp it to the end of the fuel line.
Shut it off
Shut it off
Old 01-15-2020, 10:18 PM
Sooo ordered the sending unit you gave me a link to e bay for from Tamraz. Mike did have an ohms meter and tested my old one which failed miserably as we thought it might. So thanks again 77trash......for your help.
1977 RED TA
Old 01-16-2020, 12:00 AM
Before you get the tank completely bolted back in car, hook it up to the car out of tank and verify it works. The info Canamman gave about how to test a sending unit is the gospel in testing a sender, need to write it on the wall, Lol.
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 01-16-2020, 10:02 AM
Yes Sir
1977 RED TA
