Old 01-15-2010, 11:38 PM
BAD BIRD 98's Avatar
BAD BIRD 98 BAD BIRD 98 is offline
Default 76 TRANSAM STREET CAR PUMP GAS FAST
PONTIAC ALUMINUM HEADED 467 700 HP PUMP GAS MOTOR GRP ALUM RODS EAGLE CRANK JE
PISTONS 10.8 COMPRESSION BILLET MAIN CAPS SOILD ROLLER STUDED MAINS VICTOR 4500 INTAKE WITH 1050 DOMINATOR RACE PERP BY TONY WILLISON A SET OF SD PERFORMANCE RACE PERP HEADS DONE UP WITH GOOD FLOW NUMBERS TO MUCH TO LIST IN MOTOR I WILL LET YOU KNOW THAT THIS MOTOR MAKES AS MUCH TORK AS HORSE POWER THIS IS A SERIOUS PICE FOR A PUMP GAS MOTOR WILL GIVE SPECKS OUT TO SERIOUS BUYERS RACE PREP TH-350 WITH ALL GOOD PARTS WITH ULTRA BELL WITH 8 INCH ATI 76 PONTIAC TRANSAM CUSTOM INTERIOR ALL AUTOMETER GAUGES 6AL MSB BOX WITH TIMING CONTROLER COMP 250 FUEL PUMP 12GAL FUEL CELL CUSTOM PAN UNDER CELL ALL BRAIDED LINES FROM FRONT TO REAR BM TRANS COOLER HURST PRO MATIC SHIFTER 12 BOLT 373 GEARS WITH TA COVER DRAG SHOCKS ALL THE WAY AROUND CUTOM MADE SWITCH PANIEL TRICK FRONT SPRINGS ALL NEW BALL JOINTS NEW CONTROL ARM BUSHING NICE PAINTED FRAME AEROSPACE FRONT DRAG BRAKES BORGESSON MANUAL STEERING BOX NEW CUSTOM EXTENDED TRACTION BARS I WILL TELL YOU WITH THESE BARS 60 FOOT TIMES 1.40 TO MUCH TO LIST THIS WILL MAKE SOME BODY A NICE PICE PICTURES DO IT NO JUSTED SERIOUS INQ ONLY THIS CAR WORKS VERY WELL WON MANY RACES
Seller Phone Number: 504-342-6892
Seller Phone Number2: 985-651-0292
TK $19,500.00 OR MAKE A SERIOUS OFFTER NOTE TRADE VAULE WILL BE HIGHER
Trades ACCEPTED: LOOKING FOR 98 TO 02 TRANSAM OR 98 TO 02 SS CAMARO STOCK SUSPENSION OR MIN TUB NO RACE CARS MUST HAVE STOCK DASH ALSO WILL LOOK AT OTHER CARS SUCH AS 69 FIREBIRD ARE BIG BLOCK BLOWER CARS NO BIKES ,BOATS RVS, TRUCKS NOTE MORE PICTURES ON RACINGJUNK.COM AD 1770445
Old 01-19-2010, 04:26 AM
torqjunki's Avatar
torqjunki torqjunki is offline
Default Trades
Interested in a very clean in and out third gen Camaro? 421 SBC Bowtie block, AFR 227 heads, Lunati Racer Series crank, Oliver billet steel rods, JE pistons, Super VIctor, BG Race Demon 1050 cfm 4150 style carb with replaceable venturis, etc etc. Stock style suspension. Moser 12 bolt, well built T-350 with nitrous ready converter. Runs only pump gas and seperate fuel system for nitrous. Set up to spray up to 400 shot. I have driven to track, run 5.90's in 1/8th mile on small shot, drive home. Run 6.68 on motor. All autometer gauges, AFR wide band, Lemons 1 7/8" coated headers, full exhaust with mufflers dumped at rear axle. Motor and trans just freshened, never hurt. Recent street class win at local track. 281-389-6150 Texas
Old 01-19-2010, 02:10 PM
MAY BE LET ME SEE SOME PICTURES SEND TO SLINGSHOTRACING@COMCAST.NET
Old 01-20-2010, 12:51 AM
VERY NICE CAR BUT I DONT LIKE TAN INTERIOR THANKS ANY WAY
Old 02-22-2010, 10:48 AM
torqjunki's Avatar
Default Interior??
I'll toss in some cash for a new interior if thats your only dislike.
