Old 07-31-2017, 10:31 PM
Chickenhawk Chickenhawk is offline
Default 1971 trans am numbers matching project
Car is rough rusty and needs complete restoration sat outside uncovered for 35 + years Numbers matching 455ho
4 speed with Hurst shifter. Engine is stuck has factory aluminum intake carb dates to 1972 and alternator is not correct has 5 15 inch factory rally II wheels.
Located in North csrolina
$12.500 obo
ID:	460137   Click image for larger version
ID:	460138   Click image for larger version
ID:	460139   Click image for larger version
ID:	460140   Click image for larger version
Old 08-02-2017, 09:05 AM
Bump ...... 10,500. .......harley big twin trades considered
Old 08-02-2017, 10:03 PM
Well I got the car up on jack stands to look for trans #'s and saw what looks like a hole in the oil pan.
It looks like it froze and swelled ! The bottom of the oil pan is swelled out and round. So in full disclosure the engine could be completely ruined. It got dark on me I'll investigate more tomorrow.
The number i found on the trans is 392566 from looking online it should have a 1 or 0 on the end i must have overlooked it. The tail shaft # is 3978764. If anyone wants this car make me a offer.
Old 08-05-2017, 11:30 AM
Poncho Dave Poncho Dave is offline
I came across a swelled out oil pan on a motor which sat for many years exposed to the elements. Turned out to be ok, but to be sure you could pull the intake manifold to look for cracking in the lifter valley.
Old 09-02-2017, 11:18 AM
$7500
Old 09-03-2017, 06:35 PM
pvp44 pvp44 is offline
Default 71 TA
Originally Posted by Chickenhawk View Post
$7500
Hawk, Any update on the status of the 455? Were you able to find a VIN on the M-22?
Old 09-03-2017, 07:57 PM
I have not but i really dont know where to look. If someone can point me in the right direction I'll look tomorrow. The car is now listed on ebay.
Old 09-03-2017, 07:59 PM
http://www.ebay.com/itm/1971-Pontiac...tZqvIq&vxp=mtr
Old 09-03-2017, 09:21 PM
VIN stamp on Transmission should be on the pass. side pad just forward of the tailshaft verticaly.I am watching the auction with interest but you will need to confirm that it is indeed an M-22 and the motor is not grenaded if you want to get anywhere close to the $ you are looking for.
Old 09-03-2017, 10:38 PM
I can look for the numbers tomorrow. As far as the motor being grenaded I haven't seen a rod hanging out of it but it is for sure locked up
I dont really want to pull the heads and intake but i might if it don't sell on ebay.
Old 09-03-2017, 10:48 PM
Pics of the vin tag and block vin so you can see the match
ID:	462606   Click image for larger version
ID:	462607   Click image for larger version
ID:	462608   Click image for larger version
ID:	462609   Click image for larger version
Old 09-04-2017, 09:09 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
I never thought about storing my care in a bath of salt water to keep the rodents out. Very interesting...
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 09-04-2017, 09:41 AM
I never thought about making dumb ass comments on a thread just to be a jack ass. Very interesting.....
Old 09-04-2017, 09:52 AM
lfdsteve's Avatar
Hang around for a while and you will get used to me. In the mean time good luck with your sale. ya never know...
Old 09-04-2017, 10:24 AM
Thanks. Someone will buy it sooner or later or I'll part it out.
Or i'll find a decent old firebird and build a clone.
I know this thing is rough as hell but it still is a matching numbers 71 4spd trans am.
Old 09-04-2017, 11:15 AM
With the right amt of rustfree sheetmetal & quality metal work, sure the T/A can be restored, but will it have anything close to an original born with drivetrain. Both factors are what drive a selling price. the car needs to be moved onto concrete the engine & transmission carefully pulled. With engine & trans out, the full extent of damage can be examined, only then can a prospective restorer know what he is buying..
-freeze cracked block(?)
-cylinder bores so rusty that multiple cylinders will need sleeves(?)
-cylinder heads with several chambers that are heavily rust pocked(?)
...the pic of the front of the drivers side cyl head where it mates to the exhaust manifold show serious rust damage.
-correct distributor(?) can it be removed without destroying it (?)
-carburetor, is it a water dog(?) base of fuel bowl corroded(?)
-M22...is it the original matching M22(?)
have had quite a few 455 HO projects, have even had an original M22 that was prev rebuilt with a no ring M21 input shaft & gear set. to confirm what one has, the side cover has to come off.
All of the above come into factor. If quite a few major components ck out, your chances of selling this anywhere near the price range you're asking is many times improved.
Old 09-04-2017, 11:50 AM
Thanks. I know what your saying that's why i came down on the price and yes the carb was exposed to the elements and the linkage and throttle plates are stuck.
If i go to the trouble of pulling the thing apart i will part it out that's why its still together. as far as the body goes It looks worst than it probably is I winched it out and loaded it on a rollback it didn't break in half.
Old 09-04-2017, 06:51 PM
weranc55's Avatar
weranc55 weranc55 is offline
How are the numbers on the Vin plate? Are they still legible? Was the car originally a tan standard interior?
Old 09-04-2017, 08:13 PM
Yes vin is still readable
Body tag reads
St 71. 22387nor05601 bdy
Tr 203 11 11 pnt
09
If any of you can tell any thing by this let me know
I think the 11 11 is white
And the 203 is saddle interior
Old 09-04-2017, 08:45 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Interesting. A Norwood built Trans Am trim tag would have WS4 stamped on it to denote trans am. This one does not??
203 indicates standard saddle interior
11 11 indicates cameo white bottom and top color.
Can you please PM me the following numbers:
1) stamped into the block on the front right hand side just below the head
2) stamped vertically on the driver side of the carburetor
3) numbers letters stamped on both sides of the valve stem on the rims. \\
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
