Old 02-25-2024, 10:02 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Crower Cam Saver or Hylift Johnson?
Hey guys, I am attempting the dreaded HFT cam installation in my 400 for my 62 GMC. I have a set of Hylift Johnson’s I bought from Paul K many years ago. I see Crower has a “cam saver” lifter.
Which is the best choice and why?
Old 02-25-2024, 10:04 AM
I would pm Paul on that question.
Old 02-25-2024, 10:10 AM
64speed's Avatar
64speed 64speed is offline
I’m using cam savers on my Crower cam and they seem good
Old 02-25-2024, 10:38 AM
JB Eng Wis JB Eng Wis is offline
I would say both are Good to use.... its just a roll of the dice
I you are able to do the weak single spring on break in, then the stars are all in aline...
Plus a good choice of break in oil.
Old 02-25-2024, 10:43 AM
67Lemons 67Lemons is offline
Stick with what you have, the general consensus is that the lifters made in the past are better than what we are seeing today plus the HJ’s are a quality USA product regardless.
Old 02-25-2024, 02:04 PM
grivera's Avatar
grivera grivera is offline
The ones you already have on hand
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 02-25-2024, 02:31 PM
X2
Old 02-25-2024, 02:32 PM
X2
Old 02-25-2024, 02:42 PM
i82much's Avatar
i82much i82much is offline
can you have lifters drilled for an oiling provision?
Old 02-25-2024, 09:20 PM
ponchjoe's Avatar
I thought it was the cam cores that were the issue???
Old 02-25-2024, 10:37 PM
Everything that I have read & heard points to lifters not cam cores. Plus it’s pretty much one or two suppliers for cam cores vs all the different suppliers for lifters.
Old 02-25-2024, 11:24 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Are you referring to solid roller lifters? I've had it done twice by Crower for the needle bearings. No other lifters would benefit or needed.
Old 02-25-2024, 11:28 PM
i82much's Avatar
yeah i knew abt the solid rollers but wasnt sure if you could do something with a flat tappet as well. i googled a bit and couldnt figure out what a "cam saver" lifter really is ... how do they help?
Old 02-26-2024, 01:28 AM
Nobuddy Nobuddy is offline
Crower "Cam Saver" is only for flat hydraulics. It is a flat ground in the side of the lifter from the oil band to the face as a controlled leak for extra oil to the cam lobe/lifter face. So if you need extra oiling, it might help. Other ways to do this include cutting a groove in the lifter bore down towards the camshaft. There used to be kits with a guide bushing and cutting tool that you could add the grooves into the lifter bores by hand. You would have to hone afterward. I've never used either method so no opinion if or when they help.
The tiny holes in the face of the flat lifters are only for solids. Crower calls their version Cool Face. Doesn't work on a hydraulic since it would leak down all the internal pressure and fail the automatic lash adjustment.
The Following User Says Thank You to Nobuddy For This Useful Post:
Old 02-26-2024, 05:05 AM
242177P's Avatar
242177P 242177P is offline
Rhoads offers a $29 "Super Lube" groove.
The Following User Says Thank You to 242177P For This Useful Post:
Old 02-26-2024, 05:34 AM
Dragncar Dragncar is offline
That groove is interesting. You might be able to do it yourself if you are careful and have some equipment.
Old 02-26-2024, 06:39 AM
I always use the lubed lifters on flat tappets solid and hydraulic. Just piece of mind for me. But if you already have a set of Johnson lifters I'd use those and roll with it.
https://youtu.be/XqEydRRRwqE
Old 02-26-2024, 09:22 AM
i82much's Avatar
makes sense, thank you!
Old 02-27-2024, 12:54 AM
I have never seen where the lifter is Grooved above the oil band, like show in the Rhoads pic....
Has anybody else? makes no sence to leak oil up into the lifter valley.. IMO
Old 02-27-2024, 09:23 AM
Bill S's Avatar
Bill S Bill S is offline
I had those lifters along with the Mellings 041 cam. Still had two lifters / lobes fail.
