Old 05-31-2022, 08:51 PM
ekancler ekancler is offline
Default Heads Stuck to Block
I've got a friend with a 400ci block and the heads are stuck to it. All the bolts are out. Heads won't budge. Any ideas? Crank won't turn.
Old 05-31-2022, 09:08 PM
lugnutx2 lugnutx2 is offline
Block of wood and a BFH, be prepared to catch it.
The Following User Says Thank You to lugnutx2 For This Useful Post:
Old 05-31-2022, 09:24 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Put 1 bolt in for 1 or 2 turns. Put a pry bar in a port or 2. Pull up with force. The installed bolt will help your foot survive.
The Following 2 Users Say Thank You to PunchT37 For This Useful Post:
Old 05-31-2022, 09:57 PM
i82much's Avatar
i82much i82much is offline
deadblow hammer.
The Following 3 Users Say Thank You to i82much For This Useful Post:
Old 05-31-2022, 10:11 PM
I like the foot-saving idea. +1!
Is this at all normal or more likely a sign that there's something really messed up?
Old 05-31-2022, 10:16 PM
Be careful.
That head bolt in only a couple turns could break out the top couple of threads in the block deck.
Find a different way of keeping the head from falling on your foot would be my advice.
Old 05-31-2022, 10:25 PM
tooski tooski is offline
Here's one method:
https://forums.maxperformanceinc.com...91#post6326391
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 05-31-2022, 11:11 PM
Originally Posted by tooski View Post
The scissor jack idea makes sense.
Old 05-31-2022, 11:12 PM
Be careful.
Good point. I was thinking maybe a couple bolts and maybe a few more turns.
The Following User Says Thank You to ekancler For This Useful Post:
Old 06-01-2022, 12:51 AM
Stuart's Avatar
Stuart Stuart is offline
Put the bolts in all the way, and then just back them off slightly. You just need enough slack to break the head loose.
The Following 2 Users Say Thank You to Stuart For This Useful Post:
Old 06-01-2022, 08:26 PM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
I use two short 1x2 wooden “pry bars” in the port holes to wiggle/pry them off. Gives you leverage without damaging surfaces.
The Following User Says Thank You to TxSportCoupe For This Useful Post:
Old 06-02-2022, 08:28 AM
Half-Inch Stud's Avatar
Head bolts in the corners, hidden under a oil puddle.
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 06-02-2022, 10:11 AM
grandam1979 grandam1979 is offline
I’m with you double check that you have all bolts out never seen a head stuck that bad.
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 06-02-2022, 10:48 AM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
If you have 10 bolts from each head, you got them all out. The upper, outer corners can be covered with sludge, and be disguised, in older dirty Pontiac Stratostreak engines. I've had to dig out the sludge to find the heads on a Pontiac. Count your bolts so your sure you have them all, there are 4 around each cylinder.
In this overhead torque pattern sequence the disguised bolts would be 8, and 9:
They're in the oil drain back area that tends to form sludge over the heads.
In the past, I've used a 3 ft wrecking bar to break the seal, inserted in the intake ports. Some are tougher than others. A small bottle jack would also work across the valley, if you don't have a scissor jack. They will work lying down as long as they are full of fluid, and the pump is at the lowest side.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-02-2022, 11:10 AM
Region Warrior's Avatar
All bolts out.
Good smack around outer perimeter of heads with dead blow hammer till see some movement
Old 06-03-2022, 09:06 PM
BDH79TA's Avatar
BDH79TA BDH79TA is offline
And yes, it's pretty normal on an engine that's been together for many many years.
[/SIGPIC]
Two marriages and one long term relationship later and it's the T/A that's always still there.
When referencing gas, "regular" used to have an entirely different meaning.
Old 04-17-2023, 09:13 PM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
Some gaskets used over the years seem to be sticky. Some aftermarket gaskets were like that.
Be careful.
Sent from my Moto Z3 Play using Tapatalk
Old 04-18-2023, 01:45 AM
lust4speed's Avatar
If the engine is on the engine stand just tilt it at a 45° angle where the block/head surface is horizontal to the floor. We've had a crowbar in the #1 & #7 exhaust ports but I guess you could also get a third person with a crowbar in one of the center ports. While a big four pound dead blow hammer works pretty good on intake ports, I haven't had much luck with it on heads.
Mick Batson
Old 04-18-2023, 06:01 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Feed a piece of rope into a cylinder and turn the balancer bolt or flywheel..
