Old 10-02-2022, 01:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Default Finishing some upgrades for my 80 TA
Been working on this during my spare time for a while. Kind of excited about some of the upgrades. The old combo ran 10.6 @ 127 weighing close to 3900 lbs. with driver and a full tank of fuel.
464 was replaced by a AP 496 pump gas short block.
318 87 cc E-heads were replaced with 330 cfm 87 cc.
Ported T2 was replaced with a more ported T2
175 HP integrated nitrous lines were replaced with a Big Shot NOS spray bar
Custom 3/8 in carb spacer was added to increase plenum volume and raise the hood scoop a bit.
Same carb but different boosters. Flows around 1000 cfm.
TSI tight ten inch converter was replaced with a tight ATI 8".
GM 3:42 10 bolt was replaced with Mosier 9" housing and axles with a 3.50 gear, Strange center section and Detroit locker.
Factory drive shaft with original style Lakewood u-joints replaced with Strange driveshaft and big u-joints.
Modified factory fuel tank (stock in appearance) used with two Holley blue pumps replaced with sumped fuel tank and Magnaflow fuel pump.
ID:	599768   Click image for larger version
ID:	599769   Click image for larger version
ID:	599770   Click image for larger version
Go fast, see Elvis!
Old 10-02-2022, 01:21 PM
PAUL K's Avatar
Now for the cool stuff!
Found a Hooker Show Bar from a local member here and he was nice enough to include free installation with the purchase price.
Had a factory 8k tach upgraded with modern electronics.
Came up with a sticker for my fake battery.
ID:	599772   Click image for larger version
ID:	599773   Click image for larger version
ID:	599774   Click image for larger version
Go fast, see Elvis!
Old 10-02-2022, 01:48 PM
Gach's Avatar
Gach Gach is offline
Some nice up grades…sounds good Pual..Is that the nitrous set up you bought off me ? You ever run that Comp cam you bought off me.
Old 10-02-2022, 01:56 PM
Jay S's Avatar
Jay S Jay S is offline
Looks AWESOME Paul. Your going to give those Texas tracks a proper introduction.
The Following User Says Thank You to Jay S For This Useful Post:
Old 10-02-2022, 02:13 PM
Gach's Avatar
What mufflers you running ?
Old 10-02-2022, 02:16 PM
slowbird's Avatar
slowbird slowbird is offline
The Following User Says Thank You to slowbird For This Useful Post:
Old 10-02-2022, 04:22 PM
PAUL K's Avatar
Thanks Gach, the cross plate nitrous system I purchased from you is still on the shelf. I have not been able to get the one inch plate to fit under my shaker hood (that's for my red 74). That cam ended up being used in a hi-port engine we built a while back. It worked out real nice.
They are Walker mufflers I believe they are called their "welded" series. They are a straight through design and pretty quiet.
Here's what they sound like with the old combo
https://youtu.be/PhDicneJIXs
Go fast, see Elvis!
Old 10-02-2022, 04:56 PM
Steve C. Steve C. is offline
ULTRA FLO WELDED
https://www.dynomax.com/mufflers/ult...elded-mufflers
Great muffler. I use the same one....
https://www.youtube.com/watch?v=sY76buhCPWg
Sounds like it will be a great combo Paul. See you at Ennis
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 10-02-2022, 05:23 PM
72projectbird's Avatar
That's a badass setup! I'm sure it'll fly
Love the show bar!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-02-2022, 05:24 PM
Gach's Avatar
Gorgeous Firebird thanks and thank you Steve c Beautiful bird also.
The Following User Says Thank You to Gach For This Useful Post:
Old 10-03-2022, 06:27 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Great ride . I really like the sleeper look with that car. You have certainly changed a ton in the car, excellent upgrades. I’m very eager for a report on how it works on the street and at the track .
I have a fake battery also contains my fuel pressure reg. Where did u get the tac upgraded?
Old 10-03-2022, 07:54 AM
scott70's Avatar
scott70 scott70 is offline
Maybe a 9?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 10-03-2022, 12:17 PM
ta man ta man is offline
Also interested in the tach..my stock one doesn't cut it but I have a spare 8000 rpm tach.
Old 10-03-2022, 01:14 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had a guy that redid the tach in the 81 I got from nastyZ28.com forums. Also added the higher mph speedo I had picked up years ago and matched font on the face. Nice job
Skip Fix
Old 10-03-2022, 10:23 PM
PAUL K's Avatar
Love the show bar!
Thanks... I was stoked when I found it. I initially picked it up for a friend's 70 Z/28. After I got it to the shop and started thinking about it .... I was fortunate enough to talk him out of it.
Go fast, see Elvis!
Old 10-03-2022, 10:27 PM
PAUL K's Avatar
Thanks! The gentleman that designed and built the original hood tachs that the Parts Place sold before they sourced the job overseas, modernized the tachometer.... The folks who got one of his tachs recieved a great part.
Go fast, see Elvis!
Old 10-03-2022, 10:40 PM
PAUL K's Avatar
Originally Posted by scott70 View Post
Maybe a 9?
Hi Scott, the engine probably makes enough power to run nines, but I'm thinking I'll end up around 10.20. The car twists up pretty good leaving the line. I'll soften the launch to smooth things out. I also want to install bars from the firewall to the front of the subframe. I'm hoping that will help.
Go fast, see Elvis!
Old 10-04-2022, 01:29 AM
Dragncar Dragncar is offline
I have had one of those hood tachs sitting on a shelf for years.
Your engine sounds sweet. Have fun dialing in the new engine.
Looks like you have a LS killer.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 10-05-2022, 12:09 AM
77 TRASHCAN's Avatar
What all suspension mods???
Have you made any passes at the Motorplex yet?
I used to make the trek there at least once a year.
I don't have the desire to go to all the races I used to attend. The Pontiac Southern Nats, sometimes raced at the Motorplex. I wish those days would return!!
I like your thinking on holding e.t.'s to a desired time.
Tom and Sharon Wilhites Pontiacs both run 10's easily (the red 58 and white 59, I'm sure you know of tem). Tom's white 59 has a 540 with 2 of those large single throttle bodies on a tunnel ram, Sharon's is a 505, similar combo.
Tom likes the idea of being a little easy on his engines and chassis. It also saves a lot on safety equipment and extra mods if he ran quicker.
I like that blue color, what a sleeper!!!
Jeff
Shut it off
Shut it off
Old 10-05-2022, 05:13 PM
Region Warrior's Avatar
Wow, nicely done!
The Following User Says Thank You to Region Warrior For This Useful Post:
