Old 03-28-2013, 04:39 PM
heater63's Avatar
heater63 heater63 is offline
Default Rear Wheel Bearings
Last Sunday I had a guy drop into the garage, as it turns out he lives about 45 minutes away and has a nice 63 vert 195 3 spd. After talking for a while he asked if I knew where to get rear wheel bearing for these cars. My asnwer was the typical "no"
So I searched the forum and read about the tools to remove and replace the rear wheel bearings but couldn't see any reference to "where to get them"
I've called Kanter and looked in the Ames, USA auto parts catalogs and searched the NAPA site...
So I am back here asking for help again, if anyone knows I sure would appreciate the help.
Heath
"If you aren't first, your last." Ricky Bobby 2006
Old 03-28-2013, 05:14 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
I believe you can get the rear wheel bearings from Steve's Corvairs. I am sure someone can here can confirm this.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 03-30-2013, 05:09 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
I'm in the process of doing mine. Had to cut to thr race then heat. I just bought one from Hagen's in WA. They may have more. $200.00 You have to take it apart, clean and put in new grease.253 845 7020. Try lscorvair.com or larryscorvair.com Then and now had some once 781 335 8860. South shore bearing 877 south br. John
Old 03-30-2013, 05:24 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Would "RARE' parts carry them?
Old 04-01-2013, 06:45 PM
Give'm a call!!
Old 07-28-2019, 10:08 AM
lrust's Avatar
lrust lrust is offline
Any update to this thread? A local friend of mine is trying to source rear wheel bearings for his '63 LeMans. Local parts stores including NAPA no longer carry.
Old 07-28-2019, 10:53 AM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
If corvairs use the same bearings, here is a list of corvair vendors, one of them ought to be able to help Pontiac Tempest guys get bearings:
http://autoxer.skiblack.com/supplier.html
Hopefully someone will be able to make a contact for bearings.
California Corvairs has a listing for 61-62, and also a listing for 63-64 at $210 each.
http://californiacorvairparts.com/in...oller=category
Corvair Ranch shows a bearing for $200, needs to be pressed on shaft.
http://www.corvairranch.com/rebuilt-items.html
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-28-2019, 12:27 PM
TransaxleTempest62 TransaxleTempest62 is offline
Clarks Corvair has them too. 60-2 Corvair are the same as 61-2 Tempest
63-64 is same as 63 Tempest. They used to advertise them in the Little Indians Newsletter.
Old 07-28-2019, 01:32 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
http://www.corvair.com/user-cgi/cata...?show_page=166
