Old 04-18-2018, 01:03 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
We need a clean car to test our samples on. Any volunteers?
Old 04-18-2018, 01:18 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default exhaust
I offered when you first mentioned it,unless my 66 lemans 400ci will not work.Thankyou,Tim
Old 04-18-2018, 09:28 PM
tstroud tstroud is offline
My '69 GTO is in the middle of a slow frame off semi resto. The chassis is mostly done and the body is temporarily sitting on it until it warms up outside.
What do you mean by "Clean car"?
Sent from my iPad using Tapatalk Pro
Old 04-18-2018, 11:04 PM
nytrainer's Avatar
I could bring my '68 350 HO 4 spd Lemans if that works as a test subject for you. PM if interested.
Old 04-24-2018, 01:06 PM
Ccass's Avatar
Administrator
When I got back from Carlisle, apparently the guys had secured another vehicle while I was gone. It's due here this week. If the testing of the new samples fit, we'll have systems in 6-8 weeks. If the samples need to be tweaked, that's going to add a couple of months time.
Old 05-23-2018, 02:12 PM
tempest1964's Avatar
Hey Chris, any updates on this?
Old 09-06-2018, 09:17 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Any updates? Ready to buy. My 70 is a Pro-Touring type build so a tight system is exactly what I need.
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 09-06-2018, 12:02 PM
Ccass's Avatar
Administrator
I believe we're very close to a release date. Let me confirm. However, you may run into trouble with the tailpipes fitting. Has anything been modified in the back of the car like suspension?
Old 09-07-2018, 08:59 AM
Just lowered 2"
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 09-07-2018, 12:47 PM
Ccass's Avatar
Administrator
You will probably have to cut 2" out of a vertical section of the tailpipe for best clearance.
Ccass's Avatar
Administrator
The new systems are in production. Ship date is Nov 1st.
Old 09-07-2018, 10:44 PM
What will be the final price? Any discount for Performance Years board members?
What are these systems made from? If they're stainless then cutting and welding may be difficult for the average garage installer.
Sent from my SM-G930W8 using Tapatalk
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 09-08-2018, 12:33 PM
Ccass's Avatar
Administrator
The pricing is going to be right around $500.for a header back kit with X-pipe and choice of Race Pro, Street Pro or Violator mufflers.
A introductory discount would be up to our dealers. By agreement, we are not allowed to sell retail to Pontiac customers.
Stainless- Yes you are correct. welding stainless requires different gases and stainless wire.
Old 01-15-2019, 07:05 PM
FlyJS41's Avatar
FlyJS41 FlyJS41 is offline
Apologies for the necro-post. As luck would have it, I found this discussion after pulling the trigger on a 2.5 "standard" x-pipe system (SGA10). So, what's the low down? Will this fit properly on my '68 Tempest with log manifolds? I was planing a DIY install with basic hand tools, but if fabrication is required I'd just send it back.
TIA!
Old 01-15-2019, 11:59 PM
Ccass's Avatar
Administrator
TIA!
SGA10 is Pypes' single best Musclecar system. It's been available since 2004. If you temporarily install the downpipes and then install the system from the back forward, you'll end up cutting the downpipes(prob 6-8") for final fitment
The new system installs exactly the same way. the only difference is that mufflers tuck up higher for those really concerned about OEM height clearance.
I have SGA10V on my 67 GTO. It's been on there for 7 years and I have no intention of changing it. It fits very well.
Old 01-16-2019, 08:31 AM
FlyJS41's Avatar
Thanks for your response! Are your mufflers visible from the car’s side view?
Old 01-16-2019, 02:08 PM
Ccass's Avatar
Administrator
Here is a pic. the minimum clearance is 5.75" and that's only because I have electric cutouts installed. Without them the system would be closer to 7" of clearance on my 67.
  #38
Old 01-16-2019, 04:39 PM
FlyJS41's Avatar
Thanks for the pic. I guess I’ll just have to mock it up and see.
  #39
Old 01-16-2019, 10:06 PM
goatless's Avatar
goatless goatless is offline
I've had that system on my '69 with log manifolds for years. I think that installed properly, it puts the mufflers up plenty high. Here's a side shot of my car...
1966 GTO
  #40
Old 01-17-2019, 04:48 PM
FlyJS41's Avatar
What a great looking car! Did you have to modify the tail pipe to get the factory style ends?
