Old 04-04-2019, 02:33 AM
Augie Valencia Augie Valencia is offline
Default Need a flywheel
Does anyone have a good flywheel you can sell? Mine has lots of hairline cracks. 63 Tempest, 326, A/T.
559-363-3712.
Cause they stand on a wall and they say, "Nothing is going to hurt you tonight, not on MY watch!"
Old 04-18-2019, 01:11 PM
Default Flex plate for 326
Can anyone offer advice on this item? Will it fit a 63 Tempest, a/t v-8? Or if anyone has a flex plate to sell. Thanks.
https://www.summitracing.com/parts/s...-size/5-3l-326
Old 04-18-2019, 04:00 PM
mechanickeith's Avatar
The 63 Tempest flex plate is a 1 year only plate.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-18-2019, 06:49 PM
Keith, any idea where I can find one with the same specs?
Old 04-18-2019, 06:57 PM
tom s tom s is offline
Have you checked with Ken or Dave?Tom
Old 04-19-2019, 02:23 AM
Can you give me their user names? Thanks for the response.
Old 04-19-2019, 09:40 AM
Don't think Ken is on here,East West auto.He is liquidation mode.Dave is on here.Tom
Old 04-19-2019, 09:41 AM
63 Banchee
Old 04-21-2019, 09:51 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
I have one you can have If you still need it .
Old 05-01-2019, 10:15 PM
Darren 639's Avatar
Sorry Augie for the delay.I took off flex plate today. There are no support spacers on this one but I’ll get it out to you with bolts tomorrow.does any body know if these had a support washer or spacer that would support the wheel from fatigue or cracking?
Old 05-03-2019, 01:27 AM
Thanks Darren. Does any one have a good picture of what the plate looks like? I can't seem to find one on the shop manual. Thanks.
Old 05-04-2019, 12:06 PM
Darren 639's Avatar
Default Looks like it’s cracking??
Hopefully these pictures come out. I don’t know how to enlarge them. after a closer inspection of the wheel when I was taking pictures. I see cracks that are starting to form. I have a really good talent with tig Welding. I could weld up the cracks but I don’t know if you would want to take the chance with all the labor involved ,plus if it does break it will leave you stranded.
ID:	511549   Click image for larger version
ID:	511550   Click image for larger version
Old 05-04-2019, 12:11 PM
Darren 639's Avatar
Default Yea it’s cracking
I filed some of the paint off to get a better look at the metal . I see a definite crack
ID:	511552   Click image for larger version
Old 05-04-2019, 08:54 PM
63 Banshee has full mail inbox and can't accept new ones till box is cleared. Will try again later.
Old 05-05-2019, 03:30 AM
elefantrider's Avatar
elefantrider elefantrider is offline
I don't think the cracks are a major problem. Run it until it fails, then call AAA when it don't start.
They are probably all cracked at this point. I believe a cracked flexplate will only fail when starter motor is engaged, as that is the only time it is under stress.
Old 05-08-2019, 02:21 AM
Darren 639's Avatar
That’s true......... NO converter bolted up to it!! I can weld up without much if any balance effect at all. let me know if you still want it.no problem to send it out..
Old 05-08-2019, 10:13 AM
Augie,PM sent
Old 05-10-2019, 04:41 PM
Thanks for the number Tom. I have a call into him.
He will check on the flex plate. I'm still looking.
Augie.
Darren, I'll keep you updated.
Old 05-19-2019, 06:19 PM
Darren 639's Avatar
Default Welded flex plate up
Hi Augie and Elifantrider. I’m going to try to attach pictures will see how it goes LOL. ..... I welded the cracks on the fly wheel/flex plate as it’s actually really is called.. It actually has two plates stamped together and welded together at the ring gear.Ok so only the side with the bolt Head had cracks the opposite side that goes to the crankshaft did not. I think Elefantrider is also looking for one,he is welcome to it if you don’t want or need it anymore. like I said whoever wants it to just pay for the shipping and it’s yours. I didn’t wanna throw it away figured the small cracks easily were weldable. Darren 203-650-4188 is best way to get in touch I don’t get here too often. Hope it will help someone fix their car.
ID:	512578   Click image for larger version
ID:	512580   Click image for larger version
Old 05-20-2019, 12:13 AM
Thanks Darren. I have a flex plate lined up with Bashee 63. Hopefully it will be the right one. In the meantime if Elefantrider is in need of one, get yours to him. Thanks for the pics, good beads on the weld!
