Old 06-18-2019, 02:16 PM
Mikewiththebeard Mikewiththebeard is offline
Default Clutch repair on west coast
To old to repair my 63 Lemans. Looking for a reputable clutch shop that knows how to repair/replace clutch near San Diego area. Any suggestions?
Old 06-20-2019, 02:47 PM
elefantrider's Avatar
elefantrider elefantrider is offline
4yl or V8? Do you have any replacement parts? You can get the clutch friction disk relined. What is it doing right now? Chatter? Not releasing?
Old 06-20-2019, 03:55 PM
wbnapier wbnapier is offline
I am in Encinitas.
I have used Scott's in Leucadia on Coast Highway and recommend them.
https://scottsautomotiveandmuffler.wordpress.com/
Never used, but D Mac's in Escondido has a good reputation and is known to be a Pontiac guy:
https://dmacsautorepair.com/
Never used, but Encinitas Foreign & Domestic Auto Repair has a good reputation. I've talked with the owner who restored a Firebird.
https://runcarrun.com/
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 06-20-2019, 03:57 PM
Since you are in Oceanside, stop by http://www.oceanside-driveline.com/ and ask them. They probably won't do it, but they will no someone competent in Oceanside. They are a really well-respected driveline shop and know a lot of local mechanics.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 06-21-2019, 12:58 PM
OG68 OG68 is offline
The Differential and Axle shop in Escondido. Not sure if they do clutches but give them a call.
https://www.thedifferentialandaxleshop.com/index.php
2007 Cadillac SRX
Old 06-22-2019, 12:24 PM
Doug Doug is offline
Thumbs up clutch work ---how to?
"...… knows how to repair/replace...…" ???????????????????
Well, that is the question isn't it!
I doubt that any "commercial" shop is going to have someone that has done/knows how to do this work.
I suggest you take a factory shop manual with you to show to mechanic how to do it, paying close attention to instruction on how the flex driveshaft is handled..
Also, I suggest that the driveshaft bearings are replaced at the same time as the clutch work is done. (Bearings are (may be?) available from "Chiefkey" on this forum.)
Good luck!
Old 06-22-2019, 02:43 PM
D-Mac is a true Pontiac guy. I raced in the Pontiac Drag Days bracket race series from 1993 through 2002 and Dennis was a participant. He would be the guy I’d recommend to repair your ‘63 Le Mans.
Old 06-22-2019, 03:25 PM
tolerico tolerico is offline
DMAC is retired. And his partner who took over the shop prefers working on Honda's for money these days.
Old 06-22-2019, 10:00 PM
Default Clutch
My 63 Lemans is the 336ci. Thank you all so much for your info. I did get a set of driveshaft bearings from Chief when his first production run was done and I did have Oceanside Driveline remove the old bearings and replace with new. That's all the work he cared to do on the 63. I've put 500 miles on the new clutch that a "reputable" Oceanside shop did before it fried. I did supply them an original service manual. It took them 3 months (parts) and $1500 later I'm looking for a shop that knows these unique cars. This car is the exact duplicate of one that I bought in Portsmouth, N.H. in 1966. Got drafted and had to sell it. Found this one in 2012 and cherished every moment in it. Against THANK to all that replied. I will pursue all leads.
Old 06-24-2019, 02:25 AM
You say it fried in 500 miles. What signs make you think that is the case?
Old 06-24-2019, 10:42 AM
tom s tom s is offline
Hate to say it BUT almost impossible to find anyone to work on one unless they own one.IMO doing a clutch on these things is one of the hardest thing I have ever done in the 55 plus years I have owned them and I have a lift!Good luck with your project.Tom
Old 06-25-2019, 12:20 AM
Default Clutch
Let the clutch out like a responsible driver then pushed the accelerator to the floor. Smoked the tires. The undeniable smell of burning clutch and red line at 4600 rpm. Major slipping.The installer told me there is no further adjustment left. I was never pleased with the installation. Took it back several times. This shop had no experience with the 63's. I will continue my search until I croak!
Old 06-25-2019, 01:18 AM
OK, I did some inquiring.
This is San Diego's only clutch specific shop (that I know about)... Supposedly the last stop on problem jobs. The owner of Moreland Choppers recommended them.
http://www.southlandclutch.com/
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 08-01-2019, 11:21 AM
jehanHom jehanHom is offline
Send a message via AIM to jehanHom Send a message via Yahoo to jehanHom Send a message via Skype™ to jehanHom
I know it has been a long time since this was posted, but I have not been able to find another S4 B7 Clutch DIY. With a few exceptions, the pictures are not showing up. Do you still have any of these photos, and if so, are you willing to email them to me? Thanks.
PJS
Thread Tools
Display Modes
