Tri-Power Tech 57-66 Tri-Power Talk
Old 06-20-2019, 05:45 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default tri power alternator bracket
Hi guys ,does anyone have the bracket that bolts to the waterneck for the alternator.It has to be for a 1966 tri power,and I also need the bolt that attaches the bracket to the alternator.Thanks for any help.
Tim
Old 06-20-2019, 08:20 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
If your speaking of the black painted “strap” which is fastened with a lock nut to bolt from thermostat housing, Ames has it #N142A (65-66 Tri-Power w/PS).
Chris.
ID:	514543   Click image for larger version
Old 06-21-2019, 08:33 AM
Default tri-pwr alternator bracket
Thanks Chris , I'm in the process of moving so all my books are still up north.Thanks again.
Tim
Old 06-24-2019, 05:49 PM
Default tri-pwr
Chris,do you know if they make a special radiator hose for a 66 tri pwr and a cold case radiator.It seems like the tri pwr hose isn't correct.Does anyone have any ideas on where I might get one.Thanks again so much.
Tim
Old 06-25-2019, 01:51 PM
Dick Boneske's Avatar
Picture?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-25-2019, 03:03 PM
Hi Dick,I don't have a pic right now.I thought that someone may have been through this before.I was looking at it before and I think that with some cutting ,nipping and tucking I might be able to make it work.
Thank you ,Tim.
Old 06-25-2019, 07:40 PM
60sstuff's Avatar
Tim,
Sorry, as I don’t know anything about this radiator you speak of.
I only deal in OEM cars and parts such as Harrison.
Chris.
