New firewall pad installation 77 T/A ?
Would you use the old rubber retainers or the plastic ones that come with a new one?
My old rubber ones are still good.77 trans am.
1977 Trans Am,400 4 speed,numbers matching car 1979 Bonneville ,1 owner car... 1997 Trans Am convertible,LT1/auto. |
Old ones if good. The repo ones flex and bend too much and are hard to get thru the hole
Sent from my SM-T817V using Tapatalk |
yes,old are good,not hard after 42 years!
on a related note, was there fibreglass(?) sections inserted into the ends of the firewall?
I pulled out a tattered chunk of fibreglass from mine; the day after tossing it, I thought to myself maybe it was put there from the factory, so I pulled it out of the garbage, and pieced it together for a picture.
maybe someone else can tell me what this is about(?)
I think that is what is glued to the underside of the dash top surface. They make a replacement
I have rust in the usual spot of the bottom corners of the firewall - visable when fenders are removed - infront of, and below the hings mounts;
I pulled this out of the little hole there. So unless I have grossly misunderstood you, I don't know if "dash" is applicable... Thanks for offering your suggestion though. I'll keep this chalked up as a mystery...
