Old 07-19-2019, 01:24 PM
RocktimusPryme's Avatar
Originally Posted by Scott65 View Post
You say it has a longer pinion yoke? Check driveshaft length with current set up at ride height. Make sure you're not bottoming out the trans yoke up front.
It was correctly shortened. You have to shorten it, I knew that going in. Its a well documented "How to" swap. And the sound seems like its farther to the rear on the floor. The trans yoke would be like right beside the driver.
