Old 07-30-2019, 12:56 PM
67ramair4's Avatar
67ramair4 67ramair4 is offline
Angry Body mounts, Prothane (67 GTO coupe)
I'm trying to follow instructions on which bushing to use in what spot; literally impossible. P/N 7-121 Prothane
#1 spot is the radiator support in tech support instructions, if so then #7 will be empty as there isn't enough bushings to install that way. As per Pontiac #4 and #5 were just "rubber hockey pucks" no bolts, I installed bushings, sleeves and bolts without an issue. (This in itself would cause no bushing to be available for #7 spot)
#2 spot on frame, in instructions says no bushing goes there, not so; it does require one. This spot to me is #1 as it is a body bushing and not a rad support one.
Two calls to Tech Support were useless! The are all correct size for the vehicle; even though there wouldn't be enough of them.
Question is: If anyone has used these P/N 7-121 have they had issues and if not what in the heck did you all do to complete the installation??
7-121 kit is for 67 Chevelle as no one makes any kit for the GTO.
Old 07-30-2019, 02:00 PM
You think you have an issue now, wait until you are done and driving it.
Old 07-30-2019, 07:47 PM
OG68 OG68 is offline
Not to sure about 67s but the 68-72 Chevelle coupes do not use the same amount of bushings as the BOP cars do.
2007 Cadillac SRX
Old 07-30-2019, 08:08 PM
LATECH's Avatar
LATECH LATECH is offline
This is what my 64 has at the core support.Of course not these as a replacement, but the originals that are still in there. I havent replaced them yet.
https://www.ebay.com/itm/1964-Pontia...71d3a378c45f08
Maybe you need to buy some of these here...
https://www.ebay.com/itm/1964-67-Pon...MAAOSwLopaoY3l
Not sure if the round ones would be correct.As I said , my 64 has the OE parts and they look like the square ones.
Old 07-31-2019, 05:45 AM
Jeff Hamlin's Avatar
Thumbs up Sq Rad Support Bush;
They can be sourced on line from a few different vendors.
Old 07-31-2019, 09:33 AM
I changed the body bushings on our '66 and there were 12 of them, not including the rad support. What a job. They all had bolts and they were a nightmare to get out. I've never seen where the bushings go in without bolting.
The chassis manual showed square bushings at the rad support, but the original installed ones were round. I guess it depends on the plant (ours was Kanasas).
We had no issues with the car after replacing them.
Old 07-31-2019, 11:28 AM
george kujanski's Avatar
My '67 "A" body had unbolted rubber pads on top of the forward portion of the frame wheel arches over the axle. I was replacing the bushings and was surprised to find those...needless to say, I just left those in since I had no replacements.
george
Old 08-01-2019, 05:20 AM
I've run into more then one assembled with a mix of bolt through and solid mounts (PUCKS)
It isn't mentioned in any of the assembly material, so it may have been a plant to plant item?
Also of note is most of the factory lit doesn't include the rad support
Old 08-01-2019, 01:18 PM
67ramair4's Avatar
Smile
Jeff,
This is what I was telling the Prothane tech support! I was going by the info you show, #1 is the first body mount.
Old 08-17-2019, 01:25 PM
younggto younggto is offline
Chevelle and BOP body mounts are different; Chevelles has one larger mount at the firewall whereas BOP had two sized the same as the others in that location. I had some made from Delrin for my car. ABC Performance offers aluminum mounts (the height for Chevelle which is shorter than BOP) in the correct number of positions if you’re interested.
