Master Cylinder std depth measurment
Can anyone tell me how deep a short pocket master cylinder should be & where you measure it from?
I am going to guess that the pin sticking out of the booster should just touch the center of the cylinder, but not depress it at all until the pedal is pushed? I need a spacer pin as I just realized I have a deep pocket master & a short brake booster in my GTO. I thought I had an old master somewhere to compare, but I can't find it Thanks, 68RT
68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
I found a mid 70's GM original. Not sure what its from, but it looks like I can measure from it. I would imagine there are only two types from a pin depth perspective?
Thanks!
2 pin sizes are available, one for power brakes and 1 for manual. From what I can remember the longer of the two is for power, could be wrong on that though, been a few year since I was playing with this. Sold off my booster stuff to go to Hydraboost. Will try and find measurements. Not tonight though.
64 Lemans hardtop 4spd, buckets |
More info,
> > > On the left is the long 4 inch pushrod, On the right is the 2 5/8" short > pushrod, a difference of 1 3/8". Note the O ring to seal vaccum. > > The matching master cylinders are below. Deep hole 1 5/8" on left is for > manual brakes, OR is used on power brakes with the long pushrod. > > The cyl on the right is POWER BRAKES ONLY, 3/8" depth hole, the pushrod > attached to the brake pedal arm will fall out if used on a manual system. > > Measuring depth with my dial calipers, the deep master cyl is 1.350" deeper > than the shallow. > > A manual brake pushrod is aprox 7" from tip to clevis pin.
Thanks, that helps. I believe the master I have is from a 1970 ish corvette,
It does have the 1-1/8" cylinder so should be correct, just has the deeper pin hole. After some searching I see there are some spacers made for this. Thanks for your efforts!
I just measured the depth between the two cylinders I have here. The one is 1.332" deeper. Just about 1-3/8" like you mentioned.
Thanks again
Interesting that the spacers that I am finding are called 1-1/2" I am guessing thats overall length, not subtracting the dished end that contacts the rod from the Booster.
https://www.ebay.com/itm/Deep-Bore-M...5/132374630834
Would suspect you are correct about measurement. I was able to buy a correct length pushrod from MBM Brakes, but appears they don't sell it any more.
http://mbmbrakes.com, but you can ask. Glad to help out. Just passing on info that was passed onto me. Changed out mine to Hydraboost.
Thread Tools | |
Display Modes | |
