Old 08-10-2019, 01:32 PM
mchlmacdonald mchlmacdonald is offline
Default 3-Speed Transaxle
Are there any visual signs that a transaxle is a 3-speed auto and not a 2-speed? I have a line on what is supposedly a 3-speed that I would like to swap in to my '62 to liven it up a bit but I want to make sure it is in fact a 3-speed.
Old 08-10-2019, 01:48 PM
tom s tom s is online now
No 3 speed transaxle,2 and 26 SD 4 speed autos made.3 speed and 4 speed stick shifts
Old 08-10-2019, 09:47 PM
So anything with a torque converter is gonna be a 2-speed?? Coulda sworn I read somewhere they made a 3-speed auto...
Old 08-10-2019, 10:04 PM
Yep,a basic Corvair powerglide?Tomf
Old 08-14-2019, 01:09 AM
No...the ones I was looking at were definitely Tempest transaxles, converter naked in the back and all.
Are there any 3 or 4 speed manual transaxles floating around I can scoop up?
Old 08-14-2019, 05:02 AM
Are you staying with a 4 cyclinder engine?Tom
Old 08-14-2019, 08:36 PM
Yes sir I will be keeping the 4-cylinder.
I plan on hopping up a spare motor I've got and then putting this and whatever drivetrain I choose to go with that is not a 2-speed into the car. I just know the 2-speed will be an absolute dog.
Old 08-14-2019, 09:29 PM
For strength the 63 V8 drivetrain is the strongest manual system.The 63 V8 auto is the strongest of all.Tom
Old 08-15-2019, 04:10 AM
Is the '63 stuff interchangeable or will it require some fab work? And doesn't the v8 rope drive have a larger diameter?
Old 08-15-2019, 05:04 AM
I do believe you would have to get everything from the flywheel back.Ken Freeman from East west Auto might be the most knowledgeable.Tom
Old 08-15-2019, 07:59 PM
Chiefkey Chiefkey is offline
There's a complete set-up listed on Ebay...in Illinois. Not sure where you're located. It's listed for $ 250.00 or best offer.
Old 08-16-2019, 08:59 PM
mechanickeith's Avatar
A 63 setup wont swap right into a 61-62. Lots of things are different. The 61-62 automatics can be quite peppy with the correct differential gears.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 08-16-2019, 10:45 PM
The diff gears aren't special made? They are interchangeable with other sets?
Old 08-16-2019, 11:21 PM
Not interchangeable, need to find a diff from a 61-62 automatic trans car with a lower gear ratio than what you have. look on the right side of the diff down low on the case & towards the back of the case. There are small flat spots on the diff case that has number codes stamped in the case. Look for a letter code like an H, B, A, C or J. The factory service manual has the interchange to tell you what ratio you have. The standard gear set that was used in a lot of the Tempests is 3.08. The 62's were available with 3.08, 3.331, 3.55, 3.73 & 3.90. The best all around street gear I think is the 3.331 or 3.55. 3.08 is the main highway gear, 3.73 & 3.90 are pretty low ratios mainly for in town. RPM's would really be up there with those gears.
Keith Collier
Tech advisor
POCI.org
