Old 08-11-2019, 02:36 PM
AZ64GP AZ64GP is offline
Default Headlight/Taillight Housing Gaskets
My '64 Grand Prix is about to go in for body and paint. Besides all the window, trunk, etc. weather stripping, I'll be replacing most of the gaskets that go between the various head light, tail light and reverse light housings/trims once reassembly starts after the car is done with paint.
I don't believe any of these gaskets are reproduced (at least I haven't found them from our Host). Most of them are either soft, gummy butyl rubber or are the rubber like in window weather stripping. Anything that is rubber like in a window weather stripping on my car is stiff as a board or just crumbles when I touch it. Does anyone know of a place to find reproduction gaskets like these? Are strips of the soft, gummy butyl rubber available in different thicknesses and widths where cut it and make my own?
Thank you!
Old 08-11-2019, 07:01 PM
Check with Rich Plastino at CPR. He is big on repop parts for heap big injuns.
Old 08-12-2019, 09:18 AM
cdrookie cdrookie is offline
https://www.ebay.com/itm/Brake-Tail-...53.m1438.l2649
I haven't used this yet but was going to get some and see if it'd work around my tail lights. I even thought about plumbers putty, it's waterproof, cheap, and easy to use.
Old 08-14-2019, 10:03 AM
Chief and CD,
Thank you for the replies! I'll reach out to Rich at CPR if he has anything and that gasket material available on Ebay looks promising. It looks similar to what I have for my tail lights.
Old 08-14-2019, 10:35 AM
Hmmm.....
Pontiac used a "C" channel style rubber gasket. What is on Ebay looks more like a stick-on weatherstrip.
Old 08-14-2019, 11:02 AM
pfilean's Avatar
pfilean pfilean is offline
I have purchased closed cell foam from McMaster-Carr and made my own. Did that recently to make the gasket for the heater duct to the firewall. It is available in various thicknesses and some choice of actual material. Takes a very sharp knife and a bit of patience.
Old 08-17-2019, 12:23 PM
Thank you, pfilean! I'll check out McMaster-Carr too.
Thread Tools
Display Modes
