Old 08-25-2019, 10:39 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default '63 Tempest 326 Oil Pan Removal (to fix a leak)
Has anyone been able to remove just the oil pan on their '63, with engine still in the car?
The stock exhaust manifolds hug pretty tight to the engine.
I cannot remember exactly, as it has been a while, but I think I have previously R&R'd the engine with the exhaust manifolds attached to it. Anyone else?
Old 08-25-2019, 06:17 PM
Radman's Avatar
Radman Radman is offline
Don't think it is possible with everything bolted in place. Perhaps disconnect the propeller shaft (correct name for the rope shaft), torque tube, and then lift the engine a few inches. Hopefully that will get the clearance that you need.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 08-25-2019, 06:40 PM
tom s tom s is offline
As I remember it when I tried it the engine has to come up more than a few inches to clear the oil pump.Been a lot of years.Tom
Old 08-26-2019, 10:50 AM
Thanks. I will just pull the whole engine, in case it's the rear rope seal that's leaking. I usually separate the crank bolts and the bellhousing from the engine, not the torquetube to the bellhousing. That way, you can lift the engine straight up.
I had to install the crank to ropeshaft bolts with red loctite because they kept coming out. So I will probably need to use some heat to get them loose now.
