Old 08-27-2019, 09:25 PM
shaker455's Avatar
shaker455 shaker455 is offline
Default 67' GP Front Wheel bearings will not hold!
Crazy issue here and never had this problem before:
67' GP drum front brakes
Had an issue with wheel bearings not holding adjustment and previous owner did not use seals when inspected.
Got all new bearings, races, seals, installed..same deal.
Drive it around the block, come back & jack it up..wheel is flopping!
At this point I'm thinking the machining depth on the drums where races install are wrong or the back shoulder of my spindle is bad.
Even though when I cleaned & inspected it all looked good and I test fitted bearings on spindle before packing & install.
Carburetor building & modification services
Servicing the Pontiac community over 20 years
The Following User Says Thank You to shaker455 For This Useful Post:
Old 08-27-2019, 11:12 PM
Pop the races out and see if they match the bearings; might be wrong series bearing (what brand?)
Old 08-28-2019, 09:36 AM
shaker455's Avatar
National Bearings,
Check the angle of the race vs the angle of the bearing cage your saying?
Old 08-30-2019, 12:22 AM
Originally Posted by shaker455 View Post
National Bearings,
Possible - the races could be Set 13...
Old 08-30-2019, 06:53 AM
389 389 is offline
You can get Timkin bearings on e-Bay that are made in the USA..
Check to see that the bearing race isn't spinning..
Old 11-13-2020, 02:50 AM
larrygroskopf larrygroskopf is offline
Inner bearings should be A6 or Br 6
