Tri-Power Tech 57-66 Tri-Power Talk
Old 09-05-2019, 11:34 AM
Dick Boneske's Avatar
Default '64 Tripower GTO Throttle Cable Bracket Photo
Does anyone have a picture of an original throttle cable bracket with the 1/2" spacer welded in? I have one picture, but it is very small and I'd like more detail. Note that it appears that the top portion was positioned forward by about 3/16". The second picture is of a bracket that has been cut but not welded.
I am making a batch of these brackets and would like to get them as correct as possible.
Name:	64 GTO Original Throttle Cable Bracket.jpg
ID:	519512   Click image for larger version
Name:	Carb Tags & Throttle Brackets 005.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-05-2019, 11:40 AM
Old 09-05-2019, 11:47 AM
Thanks, Bart.
They didn't do a really nice looking weld, did they?
Here is a better picture than my two on the OP. I believe this is an original, too. Note the top portion is forward of the spacer and bottom portion.
Name:	64 gto tripower engine with welded tcb.jpg
BONESTOCK GOATS
