Old 09-11-2019, 10:52 AM
Scott65's Avatar
Scott65 Scott65 is offline
I'll take the donations of these 2-4 year old plug wires off classic cars, seldom driven, stored indoors, many times climate controlled...
Old 09-11-2019, 11:43 AM
HWYSTR455's Avatar
You pay shipping, sure, I will send you mine. Are you the same type that is OK with driving on 15 year old tires too?
If you handle plug wires too much, the inner, as well as sometimes outer jackets, can break, and leak. Cross fire and arching out are symptoms, sometimes not noticeable at idle, but if you do notice it at idle, they have been bad for a long time.
Ever chase an elusive intermittent miss? 9 times out of 10, it's wires, or a cap.
I have run cast aluminum M/T valve covers for years. I've had plug wires leak so bad that they make burn holes in the fins. That gives you an idea of how bad it can be. And I have never run wires more than 5 years.
I just don't understand why people don't do proper periodic maintenance, it just makes sense, especially on a performance car.
Old 09-11-2019, 12:53 PM
Scott65's Avatar
For me, I've had vastly different experience than the things you're talking about. Probably due to the fact my car is maybe driven 10 times a year some years, and stored indoors. I haven't experienced the kind of degradation you mention. There are ways to check the condition, and I do. And when they go bad I'll replace them. But the last set I removed, someone else could still get perfectly good use from. I changed simply because I don't use a distributor anymore. Different strokes.
Old 09-11-2019, 01:34 PM
HWYSTR455's Avatar
Nah, I get it, sorry if I came across wrong, meant no harm. And yeah, you can probably get away with plug wires for more than 5 years, but like I said, silicone flat breaks down over time, just like rubber. Faster I think. It's just easier to pick an interval to change at, then there's no question.
It's a matter of how long items are exposed to oxygen. That's what breaks things down, managing temp and humidity helps, but you can't really create a vacuum every time you park a car.
The shorter the wires the better. COP is good, no plug wires. Caddys and others have a 10 year/100k service interval, other than normal 'wear' items, or used to. But I know many that have had to replace stuff that failed, and in like a 4-5 year range.
Old 09-11-2019, 08:28 PM
wbnapier wbnapier is offline
It helps to hear different viewpoints. In my case, limited time, skill, and with those wires being 25 years old, I'll replace them.
I admit, I sometimes throw parts at a problem, as opposed to doing proper diagnostic work. Lack of skill
I've ordered pretty much everything. I'm hoping to have it all by Friday and be able to do/break something this weekend. I'll keep the thread updated.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 09-12-2019, 11:31 PM
Update... I received the spark plug wires, cap, and rotor today. The spark plug wires are for a 4 cylinder. So I need to return them to Summit.
I really wanted to do this over the weekend, so I think I'll try Napa tomorrow.
Can you guys recommend a MSD set that works with Pontiac and my MSD Dizzy 8563 and MSD 6AL 6420?
Thank you.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-13-2019, 08:38 AM
I just called Summit, and they will overnight the correct set and eat both the overnight freight as well as the price difference. That's a win! I should be ass deep in this sometime tomorrow.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-13-2019, 08:41 AM
HWYSTR455's Avatar
These are my go-to wires, MSD super conductor, multi-angle boots, universal:
https://www.summitracing.com/parts/msd-31193
Old 09-13-2019, 08:44 AM
They set me up with a different MSD, https://www.summitracing.com/parts/MSD-31363
Thought?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-13-2019, 08:48 AM
I'm calling them back... The kit they suggested doesn't come with a coil wire.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-13-2019, 08:57 AM
HWYSTR455's Avatar
I don't use the pre-assembled wires, they are never the right lengths, and you end up with 2 that are very short, if they reach.
If you take your time with the cutter and crimper that come with the unassembled wires it works fine.
Interesting the pre-assembled sets don't come with a coil wire. I think that's a mis-print, I know the unassembled ones do.
Old 09-15-2019, 12:49 AM
Update:
I Removed the spark plug wires, cap, and rotor. I've added a new cap and rotor, as well as laid out the spark plug new wires. Tomorrow I'll cut, crimp, test ohms, install and start the car. Then on to the wiring.
I was disappointed to find a fair bit of corrosion inside the distributor. Photos attached. What do you think?
Any opinions on dual crimp vs. traditional crimp spark plug wire terminals?
Also, this morning I checked out the M&H engine harness and compared it with my wiring diagram from www.classiccarwiring.com. I was confused to see a black wire in the #6 terminal location of the engine harness bulkhead connector, as this is shown as empty on the wiring diagram. See attached photo.
When I checked the wiring diagram from the manual, this black wire is for the heater motor. But, on the www.classiccarwiring.com diagram, the heater motor is run somewhere else through a relay. My heater does work and there is nothing in the #6 terminal location. Any comments?
ID:	520146   Click image for larger version
ID:	520147   Click image for larger version
ID:	520148   Click image for larger version
Name:	Wiring Diagram.jpg
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-15-2019, 10:16 AM
HWYSTR455's Avatar
You have one of the early MSD distributors before they started zinc coating them. I believe you can call support, and they will replace it for you. That causes ignition issues and is a known problem.
You could disassemble the distributor and clean it up, shoot it with a coating, but it could effect the reluctor and pickup. (Don't spray the pickup). I still think they will replace it though.
Not sure I would trust those wire diagrams from that website, I would be looking at the factory diagrams, which are available, the factory service manual does have diagrams, and is basically a very good reference, pays for itself in time.
I wouldn't worry about the diagram, since everything is working. They probably used a generic or 'chevy' diagram.
The 'dual crimp' wire ends are fine, and prevent the core from breaking during installation. If you're making them yourself, push down on the core with a needle or something so it is captured during the crimp, and you will be fine.
Old 09-16-2019, 12:55 AM
I replaced the spark plugs, cap, and rotor. I mixed up the firing order on 4 and 8 when I test ran the engine. That caused some drama, but I was able to sort it out.
Of note, I used a temp light on the exhaust headers to check that all 8 cylinders were firing. All were 525-650 degrees, except cylinder 1, which was 400ish. I'm not sure what to make of that.
I have tomorrow off work, so I will test run the engine again and start the wiring. I will also call MSD and see about the dizzy.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-16-2019, 07:14 AM
HWYSTR455's Avatar
Is there a miss at idle? Or is it running smoothly?
If there's a miss, see if pulling off the plug wire on #1 makes a difference.
Not sure if the temp on a pipe is a good test, it may just be getting some breeze from the fan. Is it headers?
Old 09-16-2019, 08:53 AM
No miss at idle. Idles strong at 775-800 RPM.
Noted, and yes I do have electric fans and Doug's Headers, but all the other ones were consistent. #1 was the oddball.
I think the disparity was even prior to the fans kicking on.
I will retest today and then switch #1 wire with the old one and test again.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-16-2019, 09:13 AM
I just phoned MSD. They won't do anything about it. They told me to clean it with WD40 and drill two 5/32" holes in the cap to allow it to vent.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #38
Old 09-16-2019, 09:42 AM
HWYSTR455's Avatar
Lame. Sorry to hear. Well, I know a small hole in the cap does help moisture, but clean up with WD40 is going to take some time.
I suggest getting a new one, with vacuum advance, clean that one up, and sell it to offset the cost.
If you don't want to spend the money on the MSD unit, you can always get one of the Summit ones.
https://www.summitracing.com/parts/s...w/make/pontiac
All the new ones are zinc coated, won't rust. For $185, and probably $80-$120 you will get back from the one you sell (if you clean it up well), it's a minimal investment. And you get vacuum advance.
Take a look at the spark plug on #1, see what it looks like, make sure it's firing and not loaded up.
Is there a PCV line connected to the #1 intake runner?
  #39
Old 09-16-2019, 10:14 AM
OK, I was checking out the MSD-8528, ready to run. It has vacuum advanced and I can ditch the 6AL box. I am unsure of the pros / cons of this set up compared to what I have with the 8563 + 6AL.
I am also unsure what the pros of vacuum advance are compared to what I have. I have two ports to hook it up to. One, is the rear of center carb throttle body, and the second is a ported connection on airhorn somewhere (I think). I will look.
I will look at the #1 spark plug and post a picture later.
No, no PCV on that runner. I have a '65 tri-power set up and run the typical PCV set up off the valley pan to the intake.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #40
Old 09-16-2019, 10:33 AM
HWYSTR455's Avatar
If you want to ditch the MSD 6AL, there's nothing wrong with the Summit ready to run, and you save some coin:
https://www.summitracing.com/parts/s...w/make/Pontiac
Ditching the MSD box will simplify things, and not sure you will see much, if any, of a difference. That too you could recoup some expense if you sell it.
Yes, valley pan to intake, is that between the front and middle carb?
There should be a full time and/or ported vacuum port on the center carb, you can use whichever you prefer. I'm a full time port guy, but use whatever you feel comfortable with for now. And at the moment, that distributor does not have a vacuum advance, so adding one should help with drivability.
Do you have power brakes? Where is that hooked up?
I'm not that familiar with tripowers, but I'm sure it's easy to look up. Someone else may chime in too.
Yup, post a pic of the #1 spark plug. It's possible that there's a vacuum leak, or the center carb is a little lean. Lean would probably mean other cyls would show a diff temp too, but take a look at the plug first.
Thread Tools
Display Modes
