Old 08-28-2020, 09:27 PM
Yellow Bird Yellow Bird is offline
Default HELP please identifying engine parts.
These parts came from the 400 Pontiac engine in my 77 Trans am. The engine was refurbished and these parts came back in a small box. Can anyone please identify them for me. Thanks
ID:	548127   Click image for larger version
ID:	548128   Click image for larger version
ID:	548129   Click image for larger version
ID:	548130   Click image for larger version
Old 08-28-2020, 10:33 PM
Torquewar's Avatar
Torquewar Torquewar is offline
The first pics are timing cover to water pump sleeves. They sit in the timing cover and seal against the impeller divider spacer. Next is fuel pump eccentric bolts up to top timing gear.
Old 08-28-2020, 10:34 PM
Scott Thelander's Avatar
water pump /timing cover to block sleeves .....
definately an issue if left out
and the fuel pump .. end of cam eccentric ....
Old 08-28-2020, 10:35 PM
I got treed ..........
Old 08-29-2020, 09:10 AM
Thanks guys so much. That takes a load off my mind.
Old 08-29-2020, 11:28 AM
Grand73Am Grand73Am is offline
Pics 3 and 4 might be a hardened valve seat.
Steve F.
Old 08-29-2020, 12:58 PM
77 TRASHCAN's Avatar
Those are the pieces that go on the water pump sleeves, or on the outside of the cam eccentric.
Shut it off
Shut it off
Old 08-29-2020, 01:27 PM
I don't think they're part of the sleeves. The sleeves shown are complete with the shell and rubber grommets in them.
Steve F.
Old 08-29-2020, 08:47 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Look a bit like a valve spring oil umbrella. Or is that the outside of the eccentric? looks a little small to be that.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 09-28-2020, 07:41 PM
necdb3's Avatar
necdb3 necdb3 is offline
Pics 3 and 4 look like an exhaust gasket from manifold to head pipe. What material is it, graphite type material or steel?
Old 09-28-2020, 10:10 PM
3 and 4 are the same thing it goes around the outside of 5
Old 09-28-2020, 10:20 PM
burd's Avatar
burd burd is offline
Looks like a us quarter, before the great coin shortage you would se many of these relics.
Just Say No To 8” Flakes
F ire B irds
Old 09-29-2020, 08:35 PM
necdb3's Avatar
Agreed!!!! That's the slip ring. I see it now
