1960 Tripower Thermostat Housing Gasket & Vacuum Fitting
This was also posted in the Parts Wanted section.
I need three thermostat housing gaskets for 1960 Pontiac Tripower. This is the only year where Tripower thermostat housings had an extra outlet for the heater hose. Also, for the TEE fitting in the base of the center carb, there is a 1/8" steel tube that provides vacuum for the heater or heater/AC. I need some of the brass fittings that secure this tube to the TEE. The threads are 5/16-24. The fitting is bade of brass. I could use about three of these. Note the picture.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Gaskets are fairly easy to make.
That may be the route I need to take.
Thread Tools | |
Display Modes | |
