Old 11-24-2020, 12:26 PM
CROCIE JR's Avatar
CROCIE JR CROCIE JR is offline
Default New 3.73 on 3.23 carrier?
Customer wants 3.73 gears in his 65 BOP 8.2 Vista Cruiser. He does not want to put a new posi in it. What are my options? Currently has 3.23.
Old 11-24-2020, 12:54 PM
Steve C. Steve C. is offline
Found this...
https://www.differentials.com/gm-8-2...rential-parts/
Old information here:
Old 11-24-2020, 12:57 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
https://www.randysworldwide.com/reso...arrier-breaks/ You will have to change carriers for a 3.73 gear.
Old 11-24-2020, 02:50 PM
Pontiac Performance Author
you cudda asked dad
Old 11-24-2020, 03:08 PM
Tom Vaught's Avatar
Boost Engineer
OUCH! That had to hurt.
LOL! Happy Holidays to Ken and Crocie Jr.
Tom V.
Old 11-24-2020, 03:18 PM
Stan Weiss's Avatar
Type > BOP 8.2 rear gear spacer < into your search bar.
Stan
Pontiac Pump Gas List
Old 11-24-2020, 05:50 PM
geeteeohguy's Avatar
You need a 3.36--4.33 carrier to do it without a spacer. An 8.2 is weak enough as it is, so I would either find the right carrier, or upgrade to a later 8.5 rear end.
Jeff
Old 11-24-2020, 07:07 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Ken you know parents never know anything!
Skip Fix
Old 11-24-2020, 10:54 PM
Formulajones's Avatar
Unfortunately the 8.2 isn't popular enough for the aftermarket to make thick ring gears for the 3.23 and down carriers. That would be the easiest but as far as I know they aren't out there for this application.
You'll either have to add a spacer for the ring gear, or buy a new carrier for 3.36 and up gears.
https://youtu.be/XqEydRRRwqE
Old 11-25-2020, 02:17 PM
CROCIE JR's Avatar
Thanks Tom! Happy Holidays to you and yours.
Old 11-25-2020, 02:41 PM
AG's Avatar
AG AG is offline
I've seen an early Vista Cruiser rear and it looked stronger than the regular BOP 8.2 rears, can't remember if it had better axles.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-26-2020, 07:59 PM
The way the BOP carriers are designed, you need a NEGATIVE spacer to install a3.36 and up on a 3.23 and down carrier. I researched that 40 years ago for an article I was writing, and as a possible new part to sell for H-O Racing,
Old 11-26-2020, 10:17 PM
Tom Vaught's Avatar
Boost Engineer
I bet those "Negative Spacers", LOL, are not cheap and hard to find too.
Tom V.
Old 11-30-2020, 01:16 PM
CROCIE JR's Avatar
Dad was right the whole time! Cant seem to find the Negative spacer anywhere!
Old 11-30-2020, 01:29 PM
Tom Vaught's Avatar
Boost Engineer
Time to swap in a 4 pinion 3.23 to 4.33 Limited Slip Differential into the housing, right.
Practically every one of the TRI-POWER GTOs had a 3.23 (most likely 3.55 gear
LSD unit in them, most were a 2 pinion one.
Tom V.
Old 11-30-2020, 03:57 PM
Tom V.
All due respect, this is incorrect. The range goes like this for the original 8.2 in these A body cars: 2:56- 2:78 share a carrier, 2.93-3.08-3.23 share the same carrier, and 3.36-3.55-3.90-4.33 share the same carrier. Every original Tripower GTO I have seen with a stick had a 3.55 in it. In fact, in 45 years, haven't seen a real TP car with a 3.23 rear end...ever. Not saying they weren't built, but saying that almost every one of them came with a 3.23 has not been my experience on this planet.
Jeff
Thread Tools
Display Modes
