1951 Pontiac Chieftain Brake Master cylinder Distribution Blocks
Hello,
I have a 1951 Pontiac Chieftain with a straight 8 and I replaced my master cylinder and see that the Banjo Bolt and fitting are bad and have been modified so it still leaks. Does anyone have a solution for this fix or a place to go for parts? Thanks for the help... Curt |
Drawing is from a 1935-66 Pontiac Master Parts Catalog.
5450615 is used on other GM cars, including 1953-55 Corvettes. It is listed as "Nut with washer". 799390 is used on other GM cars, including 1953-55 Corvettes. It is listed as "Gasket, outlet pipe and connector bolt (19/32 ID x 13/16 OD - copper)". 799303 is used on other GM cars, including 1953-55 Corvettes. It is listed as "Gasket, outlet pipe and connector bolt (1/2 ID x 13/16 OD - copper)". I can't find any non-Pontiac listings for the rest of the parts.
Bill,
Thanks for the help, are those part numbers that you have listed in the left? Any idea who I could check with for NOS parts? Curt |
Look on a T Bird site. They may have one that you can make work
The difference between inlaws and outlaws? Outlaws are wanted |
Check out this Facebook group. I have been a member for several years.
https://www.facebook.com/groups/150467135123404
No, the numbers on the right like 5450615 are part numbers.
Check with the facebook group "The Pontiac Chieftain Club". They seem to be quite helpful with finding parts for the flatheads. You can join and post what you need.
Here's the link: https://www.facebook.com/groups/150467135123404 |
The Following User Says Thank You to Safari Larry For This Useful Post: | ||
Thread Tools | |
Display Modes | |
