Cam install tool
What is everyone using?any comments on the Lisle 18000
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Following
I use the corresponding sized bolt with a piece of the properly sized pipe or tubing....lil' paint and install a nice cushy bicycle handle bar hand grip....whala...instant cam installation tool.
Sorry....after checking out the link.....Your questioning a cam bearing installation tool. That unit works just fine.
Make your own for the most comfortable grip & right feel for drifting-in. Made a bunch from Wooden Kitchen chair legs;
add 3/8 threaded rod in end. add laser-cut 3/16" thick steel washers; 1 pushes the bearing, the other goes inbearing as a nie guide So you whack the rubber foot end and drift the old out. Then you load up 1 new bearing, and tap-drift in. With an eye on what you are doing it is Easy peasey. NO honing. |
That bearing install tool recommened by Bnick166 works excellent.cam spins just blowing air at it.well u get the point.A BIT PRICEY $83 but all steel construction
I've had the Lisle tool for several years and see that there are now copies out that are less expensive. Since the original post was "Cam install tool" and not necessarily about cam bearings, it might be good to point out that my Lisle kit used course thread for the assorted parts and cams are fine thread. I simply made an adapter from a bolt that now has course threads on one end and fine on the other and this allows me to use the 28" handle to easily guide cams in place.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
Post was meant to be the installation of cam bearings.
Thread Tools | |
Display Modes | |
