Good luck Greg, too bad you don't have a bigger cam to take to the dyno with you for comparison, maybe someone will loan you one? Would be nice to see both sides. I know the BOP intake will really shine with a bigger cam.
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
Well Greg I sure hope things go your way.I would say 875 hp Hope the trip goes well give me a call when you get back.
Easy 900
69 'Blackbird' 535 CID IA II SD Wide Port E-head Pro Systems Dominator |
880 HP
My 541 was designed in 2001. You have more cam and much better heads and mine made 903 HP at 6400 RPM....on methanol. I would think you would be over that number on race gas...say 910 HP.
I have a Jim Robertson sheet metal intake running twin Flying Toilets.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! Last edited by Ron; 03-10-2010 at 05:01 PM. |
I see so many chev 540's make close to 800hp on pump fuel but these poncho 541's are always close to the 900 range.
I am clueless, but why is that? or maybe I am wrong either way, sound like a SICK combo! |
850 + easy.
Why did you go with such a short rod Gregg. The cam is a bit small but it is not like the thing is tiny. Are those wide port versions of High Ports or are the stock .200 HP pushrod location. If they are those are the best flowing ones I have seen. Even if they have been moved 400cfm is still 400cfm and you will have tons of power. |
875 hp.
Dragncar i had a 4.35 stroke and went to a 4.5,the pistons only had 12 passes on them and i didnt want to spend the money on new ones so i wacked off some of the dish and put in the rod that would fit.Greg
Oh ports are .700 offset.
903 with a baby cam.
Approximately .720 at .700. Give or take a few.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Well we did some dynoing today on a mix of pump and race gas.First pull made 909 and after adjusting the ignition and cam timing we arrived at 944.To morrow we will be doing a few pulls on pump gas ill keep everyone posted.Greg
awesome greg.. i guessed 905.. 944 is AWESOME
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
very nice
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Saw 900+ coming a mile away. Even though the cam could have more duration, it's got great lift and these big inch Ponchos LOVE lift, especially with really good flowing heads. The ported BOP helps too. Congrats! Nasty setup.
Great numbers, Greg!
I'd forget the piss-gas and use the good stuff. (or maybe some more HP using alky )
#38
Great numbers so far, you should be real happy!
#39
Congrats to you and Jim Very nice #s |
#40
Wow Greg, that's great numbers. You must be happy. It's been a long hard road. Very happy for you. Talk to you soon.
