#61
The funny thing is a few months back people were trying to make fun of pump gas engines and said it was a waste of time . Like I said then and I'll say it again, with the economy in the shi__er people want to be able to drive a car if they cant afford to go racing..
#62
If you can make the power you need on pump gas the question is why run race gas? More expensive, harder to find and with pump gas you do not have to worry so much about head gaskets.
And it is always fun to beat the chevy guy with a pump gas engine vs his race gas engine with the "junk rod chucker" engine. The look on their face is worth it. |
#63
Awesome! Wow ...what an engine! 117% VE! Amazing what can be done nowadays isn't it? Congrats to all involved. Johnny
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#64
Damn - I wish mine would make power like that - HMMMMMMM good job
#65
Will we see a 1000hp on pump gas N/A?
#66
#67
You realy think so, what did Langer just make, I think he's runing 15.1 compression.
Almost 1100 hp if I remember correctly. That would realy be some thing if a pump gas motor made 1000 hp with 4 points less compression
Very impressive #'s! 540+ Chevys w/ more cam and great heads don't even come close to this thing on pump gas.
#70
Is there anyway to enlarge the dyno sheet? It is hard to read it is so small.
#71
I saved it, but still found it hard to read. It's a real small. Maybe a pump gas dyno list is in order.
That is the truth. just bumped my timing down so I could put pump gas in it. At $7 a gallon, I would rather play more the spend. |
#73
PLEASE don't take this the wrong way - but it APPEARS on my smallish, fuzzy copy that the baro reading is WAY low. Could that not foul up the corrected numbers?
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#74
Posting a larger font sheet for the old men like me that can't see...:-)
Yes the uncorrected barometer was a scant 27.73" Hg. This matched with our wall mounted mercury barometer. Normal uncorrected baro readings at the dyno are 28.20". Jim |
#75
What about substituting E85 for race gas?
#76
Lloyd, not really. If any not measurable.
Good lord, Jim. I never would have guessed the baro up there would be that low!
#78
Normal Density Altitude in the middle of the summer here is +4000'.
Remember the numbers on the dyno sheet are the uncorrected barometer numbers...which is the same as "uncorrected station baromteric pressure" used by pilots to adjust their altimeters. The numbers you hear on the news at night and on the weather channel or weather .com are corrected. The Superflow dyno software needs the uncorrected numbers. The Superflow 901 Operater's manual recommends a real Mercury barometer be installed and used to ensure accuracy. How many dyno cells have one and use it properly? Jim |
#79
All hail the new pump gas king.
#80
this motor ever see any track time to sort it out and show all its potential?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
