Old 01-21-2020, 01:57 PM
avman avman is offline
Thanks for the reply Mr. Boneske! I think that by the time we get the Boneske-fied carbs back, and we make our way back to the track, that we should be there! The new 5 speed, and clutch disc and pressure plate will require a "break in" period, and that will likely happen during the spring and early summer months of cruising around and hitting the local shows and cruise events. Vintage Air, a Wraptor serpentine belt and accessory system, new Cold Case radiator, and COILOVERS completely replacing the stock suspension, along with adjustable lower UMI lift bar (control arm) brackets on the replacement rear axle housing Quick Performance is making for us (they failed to put the adjustable lower lift bar brackets on the first housing) the 5 speed with the tricked out "White Lightning" shifter, the line lock (we haven't used yet)....
All of that certainly gives us no excuse not to make 12.8 or better.
Of course I'm going to credit you with the fast time and MPH, because you DA MAN!
Old 01-23-2020, 12:58 PM
geeteeohguy's Avatar
Originally Posted by Dick Boneske View Post
Here is the sticker you got for joining the Royal Bobcat Racing Team!
And, a few of the trophy stickers I got with my '64 GTO after doing the Bobcat treatment. Ran a best of 13.29@109.75 mph. Not bad for a daily driver in 1965!!
$100 in 1966 is equal to $793 in today's dollars, which brings the reality to the pricing seen here. Great stuff and great history as always Dick, thank you for sharing.
Jeff
Old 01-24-2020, 02:02 AM
"Titan of the Tripower"...Mr. Dick Boneske!
Old 01-24-2020, 03:52 PM
Dick Boneske's Avatar
You are a HOOT!!
Thanks,
Dick
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 01-24-2020, 05:37 PM
NYGTO's Avatar
NYGTO NYGTO is offline
avman, I hope you report back to us once you get a chance to run your car through the 1/4 mile. My '64 ran 12.70's back in the late '70's with a 400, 670 heads, Engle hydraulic FTH cam, Muncie wide ratio, M/T headers, 4.56 gears. I ran some of the first Firestone "wrinkle wall" slicks, 28.5X9" wide.
The picture is from 1965 or 1966, when I the original 389 was still running. Best with that engine with '62 Tripower was 13.29@109.75. Not bad for a daily driver in the '60's!
Mid 12's are doable with your setup. Let us know!!
That is flying! I miss racing but at one point I'm going to make time for myself.
The best time I ran with my 65 GTO was 14.09@99 mph. Automatic with 3;23 ratio and completely stock. 389/4bbl.
I'm going to get that elusive 13.99 one way or the other. :--) Great picture too!
Old 02-19-2020, 12:26 PM
I reviewed the Royal Pontiac Bobcat info again and there's another item that my dad used on his 65 GTO. He told me it had a "short throw shifter" and I see that is one of the offerings in the various brochures.
I am waiting on a F vacuum fitting to replace the crappy one that broke when I was removing the F fitting and rubber hoses from the upper and lower plane vacuum nipples of the cast iron 65 Tripower dual plane intake. I got the Mr Gasket brand intake manifold gaskets because they come with a metal heat x-over block off, and the Fel-Pro was said to have ports larger than the heads I have-those are 8777 heads, not 6777 as I had indicated earlier.
Anyway, Mr Boneske is sending the F fitting and .060 thick metal plates to use to block the heat x-over. There were a number of posts that said the Mr Gasket supplied plates would deteriorate fairly quickly, and I have repainted the intake so I certainly don't want to have to do this all over again. Also, the Cool Carb insulators are thin aluminum sheets with a polymer insulator, and they require the x-over to be blocked off.
The weather looks good for this weekend, so I plan on having the "BONESKE-FIED" Rochesters installed and ready for some test flogging!
ID:	532443   Click image for larger version
ID:	532444   Click image for larger version
ID:	532445   Click image for larger version
ID:	532446   Click image for larger version
Old 02-20-2020, 12:25 PM
Tenney Tenney is offline
Kinda cool JW GeeTo memo via Bill Sherman's C and D GTO paperwork ...
Name:	08:30:66 GeeTo Memo.jpg
The Following User Says Thank You to Tenney For This Useful Post:
Old 02-20-2020, 04:50 PM
Arrow
Jim Wangers was truly a marketing force extraordinaire!
Anyone have any updates on Mr Wanger's condition? I'm embarrased that I haven't mailed him a letter, and some hard copy pictures, which I understand was recommended by his associates to keep him mentally active.
Old 02-20-2020, 08:09 PM
Terry M. Hunt Terry M. Hunt is offline
Default Royal Bobcat Brochures
Back in the 80’s I was working in Dallas, Tx. There was a guy named Rick in the office who was a classic nerd. Somehow we got to discussing GTO’s one day and he mentioned that years earlier he sent off for a bunch of stuff from a zPontiac dealer who focused on performance models. I asked if it was Royal Pontiac but he said he did not recall. A few days later he handed me a big Manila envelope full of the same stuff Dick has posted pics of. He said he was surprised that he still had this stuff but didn’t want it anymore, so he gave it all to me. Never figured out how in the world a guy like this got interested in this kind of stuff or found his way to Royal Pontiac or managed to hang onto it for so long. What a lucky find for me !
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 02-21-2020, 12:34 AM
Talking
I welcome all links to or offers to provide me with downloads of 1965 Royal Pontiac Bobcat and GTO materials like Mr Boneske posted, but in the highest resolution.
We want to put together a STORYBOARD for the wife's 65 real GTO, Royal Bobcat Tribute car. Stuff like the pertinent price sheets are ideal to tell the story of what our GTO represents: The ultimate "Royal Bobcat" treatment, a performance purpose built 1965 421 between the fenders, under the fresh air equipped hood of our 65 GTO!
I've included some pix of our GTO, and the replacement Quick Performance rear axle housing that has the UMI adjustable lower lift bar (aka lower control arms) brackets and the Global West coilover conversion brackets attached, almost ready to go to powder coat.
ID:	532559   Click image for larger version
ID:	532560   Click image for larger version
ID:	532561   Click image for larger version
ID:	532562   Click image for larger version
Old 02-21-2020, 01:26 PM
Keith Seymore's Avatar
Nice!
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
