Old 06-30-2019, 11:36 AM
ErJaSn2 ErJaSn2 is offline
Default 1965 GTO
PHS documented real GTO. Car was built for racing in the '70's/'80's then it sat for nearly thirty years.It has a fresh .030 over 400 with 722 heads, new ferrea stainless valves,new aluminium radiator, new master cylinder,all brake lines,wheel cylinders, clutch,pressure plate,throw out bearing,new fuel tank,stainless fuel line, Borg Warner T10 (cast iron case) 4spd,Hurst inline shifter, 12 bolt rear with 4:88's and Summers Brothers axles.
Located in southern New Hampshire, $15,000.
ID:	515086   Click image for larger version
ID:	515087   Click image for larger version
ID:	515088   Click image for larger version
ID:	515089   Click image for larger version
Old 06-30-2019, 12:37 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
How much rust or rust repair on the car?
________________________________________
65 GTO
owner since 84
original ca car
Old 06-30-2019, 01:16 PM
Minor rust in rear wheel arches, lower quarters and in the trunk support areas. Floors are very solid but cut around the shifter.
ID:	515103   Click image for larger version
ID:	515104   Click image for larger version
ID:	515105   Click image for larger version
ID:	515106   Click image for larger version
Old 07-24-2019, 06:50 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
What was original engine on phs? Thank you
Old 07-24-2019, 06:24 PM
389, 4 bbl . I added a copy of the original window sticker... thanks for your interest.
Old 12-31-2019, 11:15 AM
Default A few more recent pics.
ID:	527879 Click image for larger version
ID:	527880 Click image for larger version
Old 12-12-2020, 08:24 PM
Car has been sold.
