Old 09-05-2019, 09:13 PM
Poncho60 Poncho60 is offline
Default Dog dish hubcaps w or wo trim rings?
Finally decided to use my set of NOS 1960 (only) dog dish hubcaps on my 60. Was never able to generate much interest in my attempts to sell them so figured might as well give it a shot myself. Not sure whether I should add the thin 8 lug trim rings or not.
Name:	TIRE WHEEL W RING.jpg
ID:	519551   Click image for larger version
Name:	TIRE WHEEL WO RING.jpg
Old 09-05-2019, 09:22 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
Those are nice, personally I wouldn't use the trim rings.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 09-05-2019, 09:39 PM
Stuart's Avatar
Stuart Stuart is offline
I like them better without the trim rings, but if you end up having wheel weights on the outer rim the rings may help camouflage them.
Old 09-05-2019, 09:54 PM
Thx for the comments. Weights are on the backside.
Old 09-05-2019, 09:58 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Another vote for no trim rings.
Old 09-05-2019, 10:03 PM
1965gp 1965gp is offline
Old 09-13-2019, 09:50 AM
Primal_Scream's Avatar
Primal_Scream Primal_Scream is offline
Without
Old 09-13-2019, 05:10 PM
fyrffytr1's Avatar
Without unless the wheels were a dark color. Then I would go with the rings.
Old 09-13-2019, 06:22 PM
MUSLCAH MUSLCAH is offline
With out..
Old 09-14-2019, 08:09 AM
389 389 is offline
No trim rings. They might squeak with the balance weights...
Frankly, I would just use chrome lug nuts with no caps.. That's what we used to run..
Old 09-19-2019, 09:55 PM
U47 U47 is offline
If you had a hub cap that didn't have the stamped ridges that reflect onto the trim rings then it would be ok. Since you don't, hub cap only.
Old 09-19-2019, 10:09 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
my vote is for without
