Old 11-21-2019, 09:30 PM
Default Hi blower relay
My car was missing the high blower relay when purchased. I acquired a new one. This is an A/C car if it matters. My wiring has three wires in the plug (utilizing the end ones and a middle). The relay has a the male terminals marked 1-5 . My plug can go on either way 180 degrees to use 1 and 2 (which are the ends) and 3 or 4 (which is the middle). Which way does my wiring plug into relay? This is on a 72 Lemans.
Old 11-21-2019, 10:14 PM
johnta1 johnta1 is online now
Does it look like this?
Old 11-22-2019, 06:08 PM
Yes. That's how I found what part I was missing. Standard RY22 is what I bought.
Old 11-22-2019, 06:44 PM
Is the plug flat on one side and the other have a projection in the middle of it?
Looks like the middle projection goes outward if so?
Old 11-23-2019, 11:48 AM
Both sides have a projection, just like the relay where it could fit with the middle wire toward firewall or away.
Old 11-23-2019, 08:29 PM
Hmmm.....
Maybe it doesn't matter which way it goes?
Have you tried it to see what it does?
I haven't followed the diagram to see what goes where.
Old 11-23-2019, 09:23 PM
I looked very close and it can only go one way. The plug has offsets molded so it can only fit together one way. Got it together.
