Old 11-24-2019, 02:05 PM
Terry M. Hunt Terry M. Hunt is offline
Default Which diodes go where?
Have my 55 amp alternator disassembled for a rebuild. Removed 3 diodes from the end frame and 3 from the heat sink. After examining all 6 closely I can’t find any indication of which ones are positive and which ones are negative. I will be replacing all the diodes and hope the new ones I buy are marked positive and negative, but still not sure which ones go in the end frame and which ones go in the heat sink. I’m guessing the 3 positive go together in one place and the 3 negative go together in the other place, but which goes where?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 11-24-2019, 03:08 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Diodes.
Probably should have tested them using a multi-meter on the Diode setting before pressing them all out of the heat sink. Make a hand drawn diagram of how all of those go back in.
Name:	Didoes Testing_2.jpg
ID:	525311   Click image for larger version
Name:	Didoes Testing_1.jpg
Peter Serio
Owner, Precision Pontiac
Old 11-25-2019, 07:14 AM
stellar stellar is offline
Neg in end frame and pos in heat sink. Usually they are marked red being pos and black being neg. I hope you have all the insulators in order. If you need them I have them and the capacitor with the lock ring
Name:	10DN diodes 017.JPG
ID:	525367   Click image for larger version
Name:	10DN diodes 016.JPG
ID:	525368   Click image for larger version
Name:	10DN diodes 015.JPG
ID:	525369   Click image for larger version
Name:	10 DN capacitor and retaining ring 001.JPG
