#221
So why didn't you build that Bad Azz 48 head engine...you yapped about it for long enough? Did you have those done after you windowed the block the first time because your HO heads got hurt? Yup you are clueless.... That intake would need some work to make a 1000 N/A. Is that the one I copied? Last edited by PAUL K; 02-18-2020 at 06:27 PM. |
#222
Good to know you can do 2nd grade math, based on the compression thread i wasn't sure.
#223
Lol....now we know the tards education level.
#224
This one will make 1041hp NA with my E-heads.... The one that makes considerably more power is still on the engine. Let me know if you'd like a picture.
#225
yearly bump lol
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#226
Lol.....Bunch of funny chit in this thread and another year has past with little action from the Big Yapper .
Mystic how is your Wide-port build progressing? I'm thinking 1100 plus HP is now the "big number" for E-head builds.... Quite a few 1,000 plus out there. Anxious to see some RAV results. |
#227
No not yet. We are completely over whelmed with work. That had to be put on a back burner.
#229
Sounds like your business is doing good then. That’s not a bad problem to have.
The Following User Says Thank You to dragracerx2813 For This Useful Post: | ||
#230
aluminum motor I know is being worked on at the machine shop. not sure what heads it will have yet, as I have a set of hi port and I picked up a used top end tigers (as cast). I am leaning toward the tigers, but need to get them gone through. I don't think the aluminum 517ish will be anywhere near 1000 with either head, but id like 900ish at 7600
#231
Somebody put quite a bit of effort into my Victor intake for my wide ports that I am going to use as a dyno mule before I put the Gutsram modded to blower intake on it in the car sometime this spring...
Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
#232
I'm curious about Paul K's comment regarding quite a few 1,000 + hp e head builds and 1,100 + goals. Do you feel 1,100 + e head builds are attainable and have you built any? Mike L. aside, I don't think anyone else is even close to that n/ a. I don't think there has been over 5 builds that broke 1,000.
#233
Im sure this will stir things but its a serious question, do those three show the power on the track?
#235
Yes the one hasn’t run the Et yet. But it has run the Mph.
#238
I have seen 2 of the cars run. They third car I have only seen the dyno sheet on. But it was out of the same shop as one of the others. So I am pretty sure it’s legit.
#239
I'd like to know details of these small engines that have been within spitting distance of 1,100 hp. I'm not saying it can't be done, just I have seen zero proof that it has been done.
#240
500 plus CID, Wide-port E-heads, big cam & big compression.... I'd be happy to build you one if you are in the market?
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
