Old 02-13-2020, 05:56 PM
taf44667 taf44667 is offline
Default 69 Body Mount Color/Locations - Need Input
I am in the process of a frame off restoration on a 69 Judge with 56,000 original miles and it has many identification/quality control paint marks still visible. This car has never been apart except for some items that were changed and/or removed but 99% of its original parts/hardware etc. This is a Michigan built car.
I just removed all body mounts and have a question on body mount color. I see pictures of restored cars with all types of colors red, green, purple, pink blue etc. I see In-Line also list colors. I just finished a concourse restoration on a 69 GS and the manual showed the colors/part number but the Pontiac manual just denotes part number. I do know the color was matched to a part number so the assembler could identify it easily.
What I found removing them. I have pictures but not sure how to upload them here yet.
Trunk
The mount (between frame/body) #3920609 and were embossed CHREVROLET with part number and smaller than the other mounts at 2 1/8” in diameter and had no remnants of paint at all. (Part # matches manual). The cushion (under the frame) #9787703 looks to be painted Pink/Light Purple. The bolt in this location was 3” long #9779529.
Behind Rear Wheel
The mount #9791997 embossed TEMP had no remnants of paint and was 2 3/8” in diameter. The cushion #9787703 looks to be painted Pink/Light Purple same as above. The bolt in this location was 2 5/8” long #1366144
Front of Rear Wheel and Upper Frame (4 total)
This dummy mount #9796420 had no remnants of paint and were embossed TEMP.
Door
This mount #9791997 embossed TEMP also had no remnants of paint. The cushion #9787703 looks to be painted Pink/Light Purple same as trunk and behind rear wheel. The bolt in this location was 2 3/8” long #3903321.
Cowl
The mount #9791997 (Outside) was embossed with TEMP also had no remnants of paint. The cushion #399672 was painted pink in this location. Also the bolt was 3” Long #9779529.
The dummy mount #9791996 was painted a darker blue in this location.
Summary
#3920609 mount (Trunk was black)
#9791997 mount (6 locations was black)
#9796420 dummy (4 locations was black)
#9791996 dummy (cowl was blue)
#9787703 cushion (6 locations was pink/purple)
#399672 cushion at cowl was pink.
I looked at these very closely and there could have been slight swipes that wore away but no evidence of paint in embossing or under edges of paint as mentioned above.
How does this compare to what others have found.
Terry
Old 02-15-2020, 02:19 AM
Scott Thelander's Avatar
my 72000 mile 69 JUDGE 's Fremont bushings just had a brush stroke of color
maybe 3/4" wide vertically .... very powdery paint ..
Scott
Old 02-16-2020, 09:58 AM
Brewster's Avatar
Brewster Brewster is offline
Any pictures Scott??
Old 02-16-2020, 11:23 AM
orangegtojudge orangegtojudge is offline
Send a message via Yahoo to orangegtojudge
Default Body mount colors
I am restoring a Black/Black RAIV 24237P Judge. You are absolutely spot on with the colors you found.
This is precisely what I found. Not even close the the several colors on the inline tube car. I thought , well the colors have just rubbed off over time but this is NOT the case. What is your email address or cel number? You and I are at the very same spot in our restoration. We could compare notes if you like. Chuck Compton- GA.
Old 02-16-2020, 12:44 PM
Brewster's Avatar
Hwy guys, please do share some pics of the high pigment paint markings. I have not dipped into changing mine let alone looked. Still trying to get drive line in order.
Old 10-09-2020, 09:35 PM
OG68 OG68 is offline
Bringing this back to the top again.
Replaced my bushings last year when I had the frame off of my 68 Fremont build. I also discovered the same as the OP. None of the body cushions were painted or colored. but the lower cushions were all pinkish-purple. Lavender for the lack of a better description I guess.
Had the Chevrolet mount in the rear.
All the mounting bolts were 3" except for the #3 cushion under the door. It was 2 3/8".
Attached are a few photos of the original bushings. Red paint is just overspray from a previous repaint. As you can see the paint was more than a dab and looks to have been dipped.
ID:	551124   Click image for larger version
2007 Cadillac SRX
Thread Tools
Display Modes
