Old 02-24-2020, 12:38 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Mocking up a puke can this weekend after getting header and new wiring finished up. I figure I can route breathers to it until I gt a pump on it.
Had to dodge calf deep holes walking around the shop where the freaking feral hogs have started rooting! My Ar15 has been coming out there with me lately. They used to just hang back in the woods now they have decided the dirt around the shop is good stuff.
ID:	532891   Click image for larger version
Skip Fix
Old 02-24-2020, 01:47 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I would mount that away from the engine just in case you get oil spewing out the breather.
Dave Polichena
Old 02-24-2020, 01:59 PM
Scott65's Avatar
Scott65 Scott65 is offline
Sounds like it's time to go into "offensive mode" with the hogs...
Old 02-24-2020, 03:52 PM
Skip Fix's Avatar
Thought I already posted this.
Dave not enough room to mount elsewhere. With no fenderwells little places. Radiator overflow passenger core support, driver's side no flat spots tall enough. Actually thought about putting the fenderwells back in if I need to. Was planning on making a sheet metal shield to attach to the breather on that side.
Yes starting to look a suppressors and a night vision scope for the hogs! But then you have to get rid of all the bodies!
Skip Fix
Old 02-24-2020, 04:35 PM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
I run an Aerospace in a non-Pontiac application. Mounted to the front plate, pulls from same side valve cover, and no dipstick. 12 at the stripe. And that time I forgot to drain the tank and it came out the breather, it got on the drivers side tires, and the front rotor/caliper. A mess on the car to clean up, and I will neither confirm nor deny that cleanup of my person was necessary.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 02-24-2020, 06:01 PM
Skip Fix's Avatar
I've seen a lot mounted on the motor plate.
Skip Fix
Old 02-24-2020, 06:22 PM
slowbird's Avatar
slowbird slowbird is offline
Nice thing about mount it to motor plate is you can get everything setup on the engine stand the drop it right in the car, or vice versa.
Old 02-24-2020, 07:52 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
No fender wells here either. I made a bracket and mounted them off the fender lip on the passenger side.
Old 02-25-2020, 02:43 PM
Skip Fix's Avatar
Scott what kind of double container is that? And it has the shield on one side of the breather.
Skip Fix
Old 02-25-2020, 04:42 PM
I made the 2 separate cans. 1st one is a separator so no oil gets to the "vacuum" pump. ( I run a Ford Smog pump and it cannot tolerate oil ) then after the pump is the vent can. The Moroso breather does have a shield around it.
Old 02-25-2020, 06:00 PM
grandville455's Avatar
grandville455 grandville455 is offline
Here’s mine skip
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-25-2020, 06:21 PM
slowbird's Avatar
Originally Posted by grandville455 View Post
Here’s mine skip
Stinking ProMod, no fender wells
Old 02-25-2020, 07:48 PM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
Mounted mine up front
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
Old 02-25-2020, 07:50 PM
Skip Fix's Avatar
Darby a Star pump? Looks like a motor plate mount for the pump.
Camaro does not have the big fender support bracket Firebirds do, but maybe like that or Scott mount the tank in the fender.
Skip Fix
Old 02-25-2020, 07:52 PM
cgeise's Avatar
cgeise cgeise is offline
here is my experience -- Star pump will NOT tolerate oil in it -- the vanes tend to stick, Moroso lives with some oil much better -- Bill is the owner of GZ easy to talk to and he will take care of ya --
Old 02-26-2020, 08:48 AM
Yes A star Pump mounted on the plate
Darby
Old 02-26-2020, 08:51 AM
Promod weight too lmao!
Darby
  #38
Old 02-26-2020, 11:08 AM
Skip Fix's Avatar
Dang Darby I thought you were a little lighter than that!
Skip Fix
  #39
Old 02-26-2020, 04:56 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Here is another picture that may give you some mounting ideas for the catch can.
Bob,
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
  #40
Old 02-26-2020, 08:37 PM
Bob,
Nice!
