Old 05-29-2022, 12:17 PM
mark5775 mark5775 is offline
Default Proper adhesive for under hood
Can anyone tell me what is the factory adhesive they used to glue the under hood frame to the outer shell. The globs of glue on mine are dried and separated.
Old 05-29-2022, 01:07 PM
Half-Inch Stud's Avatar
Good question, my original Decklid has that separation.
Old 05-30-2022, 11:36 AM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
I believe the factory used a seam sealer here. Same type of material used to seal the plugs on the floor of the trunk. 3M sells excellent products but expensive. These sealers come in a few colors. Here is what Amazon sells; https://www.amazon.com/3M-Urethane-S...007NIQONO?th=1
Old 05-30-2022, 12:59 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Lord FusorŪ 121/124 Flexible Foam would be the product to fill the gap between the skin and brace. Stays flexible and allows the skin to move when it expands and contracts.
Old 05-31-2022, 11:47 AM
dataway's Avatar
dataway dataway is offline
This is the 3M product that is made for that particular application
3M NVH Dampening Material 04274
But, it's kind of stupid expensive, and requires a special gun to apply it (about $60). I recently used it on my hood. After curing it sure seemed to be extremely similar in behavior to the urethane seam sealer. I used it under the hood because of the temperatures and fumes in that location. Not sure I would use it again considering the price ... I still have to do my deck lid.
Big Bear ... do you know if the Lord Fusor product will work in the the 3M gun? (3M Manual Cartridge Applicator, 08571)
Old 05-31-2022, 10:05 PM
Big Bear's Avatar
Dont know if the gun will work on both products. There is only about $6 between the two products and 3M is a good product. Wouldnt change brand and chance the gun not working if I already have the 3M gun.
The Following User Says Thank You to Big Bear For This Useful Post:
Old 06-01-2022, 01:54 AM
dataway's Avatar
Annoys me that the 3M product is not expanding (like OEM obviously was), so the product does not go far at all and doesn't look the same without the "puffy" globs in the gaps.
