Old 06-04-2022, 10:56 AM
supersport#69 supersport#69 is offline
Default 68 vinyl top molding
I’m in need of a couple of things.
The vertical molding that looks like a curved L behind the quarter glass is missing a clip. The clip attached to the molding and has a head that pushes into the quarter panel itself. Is the clip in this pic correct?
Is the kit for that molding? The one between drip rail and quarter panel.
Also I can’t seem to find nuts that secure the hood scoops to the hood.
Old 06-04-2022, 11:08 AM
Default Clips
Is the kit for that molding? The one between drip rail and quarter panel. I need these clips? Anyone know where to find them?
Anyone know the name of the clips?
ID:	592139   Click image for larger version
ID:	592140   Click image for larger version
Old 06-07-2022, 05:00 AM
dataway's Avatar
dataway dataway is offline
I think that kit is for the molding from the L shaped piece, back to corner piece (the two nuts) and across the panel at the top of the trunk.
I didn't even know that L shaped piece had a clip, thought it was just the two screws ... so I probably need the clips too.
I bought a box of 50 speed nuts from Aveco (?) ... seems to fit many applications that use them ... I'll check and see if they fit my scoop inserts, I still have a few of the original nuts attached to them. Places like McMaster have a good selection of speed nuts of various sizes ... but you gotta figure out what size you need.
Old 06-08-2022, 05:21 AM
dataway's Avatar
The nuts I'm going to use to replace missing OEM scoop nuts are:
Auveco PN 3404MC
3/16 stud size
1/2" OD flange
3/8" Hex Head
Tested them and they seem to fit fine on the scoop threads.
Don't see the equivalent on McMaster, or anyone selling less than a full box of the Auveco.
PM your address and I will send you a dozen of them ... I bought the smallest box ... 100 of them I'll see if they make it through in a letter envelope.
