#121
Use dynamat or an equivalent sound deadner
If not the panel will sound very tinny and not solid at all |
#122
Thanks for the suggestion on the Dynamat. I've got some in the shed from an earlier project.
In other news, I'm fabbing up some reinforcements for the chassis rather than buying them pre-made. Got the rear section tacked in tonight.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#123
Finally got all the reinforcements welded in and cleaned up today. Came out pretty decent! Took a while to make everything from scratch, but it was worth it.
#124
Nice work and craftsmanship
Keep it going! |
#125
Looking good...planning on doing the same to the frame for my Tempest but I'm thinking of "swiss cheesing" the boxed pieces to save some weight
#126
Anyhow, today I just did a little finishing work on the welding. Also fixed the "handiwork" left by a previous owner...
#127
I also thought about a dimple die...but of course I don't have one. I suppose I could just drill large holes. It would still have to make the frame way more rigid than the factory did.
#128
Either way, I think you'll be glad you boxed the frame. It's pretty striking just how insignificant the frame is from the factory.
#129
I didn't realize the added weight was only 10lbs...thanks
#130
Time for a small update. Got the rear deck substructure and outer panel installed, and finished the sail panel repair. Pretty amazing to have all the rust gone in that area. Now moving onto lower fender patches and then the tail panel and trunk pan. Took a while to get where we are now, but it should start picking up as the rear deck area was probably the most intense part of the bodywork.
I've also decided to paint the frame myself, so I've been slowly scraping, wheeling, and stripping it down to bare metal. It's tedious, but I think it'll come out nice.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-15-2020 at 09:49 PM. |
#131
Awesome work, mine needs the same areas replaced and I have that scheduled for 2022, lol. Great progress and very nice attention to detail.
Randy |
#132
If you're going to be replacing the rear deck substructure and parcel tray like I did, you'll probably want to save the photo above that shows it without the outer panel installed. Nobody makes a GTO rear deck substructure, so the only option is to modify one that is intended for a Chevelle. This entails extending it by about 5" or so to fit the GTO body dimensions. You can see where it was extended in the photo above where there is gray paint on it. EDIT: Here is another photo showing the rear deck substructure extension that was needed.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-16-2020 at 01:22 PM. |
The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
#133
Good grief, I think I'm finally in the home stretch with refurbishing the frame. I decided to clean and paint it myself to save some money over having it blasted and powder coated. Took an eternity to get it down to bare metal, including the nooks and crannies, but it came out nice. My angle grinder definitely got a workout with this task.
For all the old timers who say they don't make 'em like they used to, take a gander at the front crossmember welds. Must've been slapped together on a Friday afternoon before a holiday weekend, by Ray Charles... I'm going to clean them up and re-weld, just because I can do so easily at this stage.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-23-2020 at 09:39 PM. |
#134
Keep up the good work. All of those little details that no one sees pays off in the end. Mine says hi from Michigan..
Sent from my SM-G970U using Tapatalk |
#135
Thanks for the words of encouragement! Yours is a beauty, and a post coupe like mine as well. Very cool. I'm originally from Michigan, too (East Lansing), and my GTO was built in the Pontiac, MI plant. Possibly yours was, too?
#136
holy Toledo you have that frame looking like chrome. how long did that take? what do you suppose you'll paint that with?
#137
For paint I'm going to be using Eastwood's chassis black satin finish. I'll also be using their internal frame coating.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 02-24-2020 at 12:53 AM. |
#138
Dang, that's almost too pretty to paint!
Greg Reid Palmetto, Georgia |
#139
Thanks! Some of the guys at the shop have been joking with me that I should just throw some clearcoat on it. I can't recall if that was before or after they made fun of me for how long it took to clean up.
#140
I am glad I sent mine out for blast and powder - 40 hours of what you did by no means is fun. How are you going to run your fuel and brake lines? Most kits are either hardtop/post or conv't - yours is neither now frame-wise |
Thread Tools | |
Display Modes | |
