Old 02-17-2020, 09:18 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Default Stupid jack question
I'm definitely missing something here (I mean, apart from the mini spare)..
How does this all mount? 1971 Trans Am..
I can see the two mount points but the jack column isn't even long enough to reach from the one to the other..
Sam
Name:	2020-02-16 10.03.28.jpg
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 02-17-2020, 10:18 AM
Go to the Ames performance site and look at there replacement jacking decal for the TA's trunk.
Old 02-17-2020, 10:28 AM
track73 track73 is offline
There are holes in the bumpers that the "hook" fits into to jack up the car. You are missing the lug wrench.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 02-17-2020, 10:49 AM
I have always found that a small crank type scissor jack pirated from a small car to work better and be far easier and safer + overall take up less room!
Old 02-17-2020, 11:05 AM
242177P's Avatar
242177P 242177P is offline
Lightbulb
The way I read this thread is 'how were original jacks stowed?'
Old 02-17-2020, 11:17 AM
400 Lemans's Avatar
https://www.webeautos.com/details-19...70n120124.html Scroll to the trunk pics.
Old 02-17-2020, 11:22 AM
neilfreeb's Avatar
neilfreeb neilfreeb is offline
At this location is the trunk sticker, but not real clear on stowage.
Sorry, couldn't upload the image.
If memory serves (from about 50 years ago), the bottom plate went on top of the spare, screwed down solidly. The upright was held underneath, I thought with a bracket on the trunk pan. (Mine was replaced without it so can't say for sure).
Last edited by neilfreeb; 02-17-2020 at 11:26 AM. Reason: link to image didn't go in
Old 02-17-2020, 01:50 PM
Default Pictures
Clay
Name:	70 trunk.jpg
ID:	532244   Click image for larger version
Name:	70 trunk 2.jpg
ID:	532245   Click image for larger version
Name:	70 trunk 3.jpg
Old 02-17-2020, 02:03 PM
Scott Thelander's Avatar
SWEET detail work
love the red oxide showin and the dove gray on the wheel and polyglas GT
Old 02-17-2020, 02:42 PM
glhs#116's Avatar
It's under the rag
Sam Agnew
glhs#116's Avatar
Yes.
Sam Agnew
Old 02-17-2020, 02:48 PM
glhs#116's Avatar
Originally Posted by "QUICK-SILVER" View Post
Clay
Hmm.. Now that's a bigger mystery. So it seems there should be some sort of bracket between the two you see in my picture. One that the spare should mount on. And it looks like I'm also missing the upright threaded piece and the big wing nut. But more puzzling to me is I don't even have a hole in my carpet where the centre of that wheel would be. All I can really see is those two brackets. And they are both look like they are for the jack shaft but they are further apart than the jack is long..
OK. Anyway, looks like I don't have enough bits to hold down the ones I do..
Sam
Sam Agnew
Old 02-17-2020, 03:31 PM
1969GiPper 1969GiPper is offline
Sam
How long is the jack you have and how long would it need to be to fit in the two brackets? Also I believe there should be another bracket that the hold down screw hooks to. In your case it should be under the carpet/mat about halfway between the two jack brackets. If it’s not there there should be evidence on the trunk floor of where it was welded to the floor at one time. To me it looks like you have the wrong jack, probably the wrong jack base and are missing the hold down screw, wingnut and the washer that goes under the wingnut.
