Old 01-14-2020, 06:27 AM
Mickey_London Mickey_London is offline
Default 1970 Firebird Heater Blower
Hi everybody
When I bought my car ( it is a 1970 Firebird Esprit ) it came with the heater and blower removed. And in place is a heater motor from a classic Austin Mini
Like this one
Name:	Austin Mini Heater Unit.jpg
It works fine but is not right
So I take it I will have to re-cut these areas in red on my firewall/bulkhead
Does anything else have to be cut on the firewall/bulkhead ?
I also have this, will this be the correct one for the inner heat box
Name:	screen demister.jpg
I will need to get the inner and outer heat boxes but will it be for A/C or non A/C
I am not be bothered with having A/C but don't know if they are interchangeable with the bulkheads/firewalls
Thanks Guys for any input
Mick
Old 01-14-2020, 08:36 AM
Ok, so after a morning of being on Google I have come to the conclusion that my firewall is for A/C
So my next question is, as they seem more readily available, will non A/C heater boxes, inside and outside, fit my firewall with a bit of cutting of the firewall.
I am not afraid to use my angle grinder :-)
Mick
Old 01-15-2020, 09:39 AM
dataway's Avatar
dataway dataway is offline
Hey ... somebody help this guy out!
Old 01-15-2020, 10:33 AM
steve v's Avatar
steve v steve v is offline
That looks like a non-ac firewall to me.
Old 01-15-2020, 11:30 AM
unruhjonny's Avatar
that vent duct is for an A/C car;
The metal attaching tab is the clear identifying point to me.
So is your firewall currently flat/smooth?
You could probably get a firewall section from a dismantler like Franks Pontiac Parts, Second Gen Graveyard, or someone here...
Depending on what your car started out as, or what options you would like to have, you can determine if you want to do, because at this time it sounds like you can set it up as either an A/C car, or a non-A/C car...
1970 Formula 400
Old 01-15-2020, 01:33 PM
From what I can see on Google it is a firewall for A/C cars.
So I will get ine of the A/C delete kits at some point and the inner box for the heater core. I will then be sorted and will be able to remove the Austin Mini heater box from under my dash.
The holes for the outer heater box have been plated over but I think they are just stuck in not welded
Thanks guys :-)
Mick
Old 01-17-2020, 05:38 PM
JUDGE3 JUDGE3 is offline
looks like its NON ac.
this is a 73 firebird with air conditioning, I don't think its any different for 70-73. much different heater core location etc.
Old 01-17-2020, 06:43 PM
Hi JUDGE3
The picture you have put up is like my firewall.
If you look at the picture of my firewall, the holes for the blower motor and EVAP have been plated over from inside. I have outlined them in Red
The two pipe connectors you see on mine are coming from the Austin Mini Heater box, inside my car.
I will remove the plates next week, and the Austin Heater box.
I have bought an A/C heater inner box, and will get it ready to fit. Needs a bit of a tidy up. Will take about 2 weeks to get here though
I am currently trying to get an A/C delete box kit from here https://www.acdelete.com/pages/70-81_F-Body.htm
But they are not answering my emails for some reason
Thanks JUDGE3 for helping and everyone else
Much appreciated
Mick
Old 01-17-2020, 10:18 PM
got it.
did the same thing.
used the non ac control faceplate inside after the changes.
Old 01-18-2020, 04:54 AM
Thank you JUDGE3
I bought a Non A\C faceplate a few months ago, because all I had was a hole
So sorted out my dashboard
Before pic
And after
Thanks again to everyone
Mick
Old 01-27-2020, 04:04 PM
Ok
So I recieved my A/C inner box today.
Because I will be running with A/C delete my heater controls in the dash are for non A/C cars. But I have no control cables.
So my next question is will non A/C control cables fit to a A/C heater box that holds the heater core.
Thanks for any help
Really appreciate it
Mick
