Old 01-18-2020, 09:45 PM
Default Emblem repair
Anyone ever try to repair these with any success? The one is from a '66 grille and the other is from the tail panel of a '66 Tempest Custom. I've replaced them both, but I could never find one like this tail panel emblem with white painted letters.
Old 01-18-2020, 09:47 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
I've had a small amount of luck with Super Glue, but not for long. It eventually breaks again. I decided to buy a replacement, and then glue my original together to sit on the shelf.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 01-19-2020, 09:15 AM
Jeff Hamlin's Avatar
I think the '66 was the last year for the painted inside of the lettering.
As I'm you know these are somewhat hard to find in good condition.
The '67 is a completely different design that some think will work, but it will not.
I would make a flat metal jig/plate with needed holes punched for the pins and make sure it all lines up and is flat.
Once satisfied Clean both area real well and clamp it onto the metal via speed nuts.
I would try to use small amounts of JB weld for the bonding.
Cover the plate with foil so the weld will not bond to the plate.
Its worth a shot.
Old 01-19-2020, 12:32 PM
BOB VIDAN BOB VIDAN is offline
I have a 66 grille emblem, PM if interested.
Practicing social distancing for 65+ years
Old 01-20-2020, 08:52 PM
Thanks for the suggestions, guys.
Bob, thank you for your kind offer, but I did replace the grill emblem already.
Cheers.
Old 01-26-2020, 08:45 PM
GT182's Avatar
GT182 GT182 is offline
Once broken the emblem is almost impossible to repair seeing it was potmetal. As Jeff says there is a small chance to "weld" it together using JB Weld. I've tried with something, I can't remember what it was (I don't think they had JB Weld back then, but may it's what I used), and it didn't last long enough to put it back on the grill... no matter how careful I was. I tried 3 times, gave up and bought a replacement. And that was back in 1973 when I had the 66 Tempest Custom.
Actually the replacement ended up to be the complete change-over to the GTO front grills and lights... all for $75.00 at a Pontiac dealer down the street from me in Rochester, NY.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Thread Tools
Display Modes
